Hi Thbis is going to sound stupid but how do you remove it. Basicly i installed it to stop my sister messing up my pc and now i cant remove it as it saids my password wrong. If i try to use forgot my password it crashes. Any ideas
lol... ok so your parents installed it and you want to look at porn... so you want it uninstalled. if it crashes during the forgot password bit then go to netnanny tech support. if you are genuine..... otherwise do as your parents wish till your old enough to legally look at it
you can "remove" it the dirty way, that is by deleting or renaming some of its dependancies, dlls and such, they shouldn't be pswd protected also to delete logs and such end its process and for the few seconds its down the logs shouldn't be protected... but you didn't hear this from a 15 yr old
