Windows Netbook as glorified remote?
Discussion in 'Software' started by FILTHY1337, 3 Feb 2009.
  1. FILTHY1337
    FILTHY1337 Senior Overclocker
    4 Jan 2004
    so im thinking about getting a dell mini9 and i was wondering if there was an easy* way maybe even with a nice GUI (not explorer) to control my media center (video/ music), and play over home theater speakers. Think it can be done from ubuntu? or would i have to go xpz?
  2. GoodBytes
    20 Jan 2007
    Get Windows Vista Home Premium or Ultimate 64-bit.
    They both come with Windows Media Center. You can buy a Windows media center remote with remote sensor which you can put on your TV (all you have to do is plug it on your laptop when needed). Of course if you don't plan to attach it to the TV, then you can use keyboard and or laptop mouse to navigate like any thing.
    Also good 32 and 64-bit DVD codecs are provided.
  3. FILTHY1337
    4 Jan 2004
    not sure how well a dell mini 9 would handle would handle vista or any media center(it may only have a 4 gig hdd). Im looking for something more lightweight. an ms ir remote isnt gonna work me, i would need LOS to the receiver.:duh:
    the main media pc is 64 capable and already runs almost every flavor of windows and ubuntu, but i don't believe the atom CPU is 64-bit. Remote desktop might be a solution but i don't know yet because the media pc has triple monitors , how would this behave on a 9in mon?
  4. GoodBytes
    20 Jan 2007
    hmmm you are right.... Sorry, my mistake. I forgot that the Dell mini had an Intel Atom CPU.
  5. FILTHY1337
    4 Jan 2004
    an ideal solution would be a web ui like utorrent has with an interface like carpc media software (ie. roadrunner).
    thinking about it that may work for seeing the files, but how to i make the media output to the server's display+audio
  6. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    How about fooling the main PC into thinking it has another screen, VNCing into that and plop the media player on it?
  7. FILTHY1337
    4 Jan 2004
    i like the way that sounds but whats vnc?
  8. Cupboard
    30 Jan 2007
  9. §§...
    §§... What's a Dremel?
    19 Mar 2003
    have you heard about netremote?
    no experience with it myself, but have to pay for the software and draw up your own interface i think, what you want looks to be similar to what this guy has done...
