Scratch Build – In Progress Netbook Based SFF Aluminium HTPC
Discussion in 'Project Logs' started by a1computers, 4 Mar 2012.
  1. a1computers
    a1computers What's a Dremel?
    17 Feb 2012
    As you can see I'm new on here and this is my first ever project. For some time I've needed something to play movies stored on my Freenas box through my TV. Due to the location it would need to be no bigger than a standard DVD player. After finding other peoples projects on here very interested I remembered I had this
    A motherboard from a damaged Samsung NB30 Netbook. So I thought I would have a go at a project myself and make a custom aluminium case for it. No CNC or specialist cutting tools here, below are some of the tools and materials I'll be using for the project
    Started cutting the aluminium base, sides and front to the correct size
    Thats all for now, thanks for looking, more updates to come
  2. McDuff32
    McDuff32 Minimodder
    5 Aug 2011
    Ooo netbook! Going for that sleek look? Good luck! :)
  3. a1computers
    17 Feb 2012
    I think this will turn out to be a fairly basic project as its my first attempt and on a strict budge using mostly bit and pieces I already have, but hopefully It wont turn out to bad and serve its purpose well.
  4. Fredo428
    Fredo428 What's a Dremel?
    19 Sep 2011
    Nice project !
  5. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    looks like fun!
  6. Amsalpedalb
    Amsalpedalb What's a Dremel?
    24 Nov 2010
    Hmmm, you've given me an idea for my netbook with a cracked screen.
  7. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Great. Always wanted to see something like that. ;)
  8. The Crusher
    The Crusher What's a Dremel?
    5 Mar 2012
    Nice, cant wait to your new update :)
  9. a1computers
    17 Feb 2012
    Thanks everyone for your positive comments
  10. a1computers
    17 Feb 2012
    So far I've already had or been able to borrow the tools I've needed, here's a few more that have proved very useful
    Holes drilled and tapped and stand off's fitted, ready for the motherboard and hard drive. Also cut out the front panel for the power switch
    Trial fitted the motherboard and hard drive
    And cut out one of the side panels for the USB and screen connection
  11. peteski
    peteski long live the pc
    8 Jun 2011
    nice idea mate cant wait to see how it comes out :rock: :rock: :rock:
  12. dreps
    dreps Minimodder
    3 Oct 2012
    to bad there is no update since this long :/
