Build Advice Netbook conversion build
Discussion in 'Hardware' started by I'm_Not_A_Monster, 4 Feb 2009.
  1. I'm_Not_A_Monster
    I'm_Not_A_Monster Hey, eat this...
    22 Dec 2003
    i'm about to buy an Averatec 2100 laptop from a friend. I already have a laptop, and this is small enough to be very portable, why not make it into a quasi-netbook?
    i think i'm going to remove the hard drive, and replace it with a 2.5" IDE to Flash memory adapter, I'd like to cram a GPS receiver in there too, right alongside it. the Hard drive has a cage assembly that would make a handy mount for everything there with a bit of dremeling. the cage is roughly 4" x 2.75" x 0.4" so space is at a premium.
    which would be the most cost-effective way to go for flash memory? i want at least 8GB but 16 or 32 would be nice. The thing i really care about is finding the smallest IDE -> Flash adapter out there, since that will be the important thing when all is said and done.
    I think this would make a pretty sweet little rig for keeping in the car or bringing to class. I want to embed a GPS receiver so i can use it for navigation (got that idea from a modded eeepc lol).
    also, is there a particular GPS receiver that works best with linux? thats what i'm going to throw on it
  2. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    I'd go for a usb thumb drive. Corsair has them up to 32Gb. Just crack the case open and shrink wrap the board for a nice small drive. I'm pretty sure that laptop has a couple usb ports on the outside, just unsolder one of the ports and wire the flash drive to that port. Hell, you could probably stick in a small self powered usb hub in the place where the drive used to sit, and stick a couple drives there. As for gps, I don't know of any "good" linux mapping programs. If you have an internet enabled cell, you could tether and use google maps.
  3. I'm_Not_A_Monster
    22 Dec 2003
    that is an option, but i'd rather use a small IDE to flash adapter so it'll be faster. i'm gonna have a free IDE slot, and i'm going to be tying a USB up with the GPS, so might as well use the IDE right?
  4. Altron
    Altron Minimodder
    12 Dec 2002
    Any updates dood? You ever find a good GPS receiver and software package?
