Networks Netgear DG834PN & Hauppauge Wireless MVP
Discussion in 'Hardware' started by jezmck, 17 May 2007.
  1. jezmck
    jezmck Minimodder
    25 Sep 2003
    I have an MVP (http://www.hauppauge.co.uk/pages/products/data_wmvp.html) and have just bought a new router (http://www.netgear.co.uk/wireless_modem_router_dg834pn.php.
    I did once get the MVP working wirelessly with my previous router, but have been unable to do so with this new one.
    I haven't been able to tell which of these is the cause of the problem - all I know is that the MVP says either of the following depending on how it's feeling.
    • Cannot obtain an IP
    • Connected to the Wireless Access Point but cannot obtain an IP
    Any suggestions will be hugely appreciated.
  2. jezmck
    jezmck Minimodder
    25 Sep 2003
    bumpette :)
  3. capnPedro
    11 Apr 2007
    Is DHCP enabled on the router?
    Any forms of encryption?
  4. jezmck
    jezmck Minimodder
    25 Sep 2003
    (sorry for my slow reply, and thanks for your reply)
    DHCP is on, WEP is on (and is supported by the MVP, and turning off makes no difference)
