Networks Netgear WGU624 + NTL = stops working after a few hrs?
Discussion in 'Hardware' started by boycee, 5 Nov 2005.
  1. boycee
    boycee What's a Dremel?
    9 Jan 2002
    I have just bought a Netgear WGU624, however for some unknown reason after a few hours all the connect pc's get "limited or no connectivity" and this is solved by simply resetting the router. Then it works for a good few hours again before it goes down again?
    I'm assuming this is perhaps a setting problem, anyone got any ideas?
    Many Thanks
    Chris
  2. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    Is the router hot when this happens? It could just be overheating. Have you tried resetting the router to factory defaults?
