News Netstor's external PCIe caddy for notebooks
Discussion in 'Article Discussion' started by CardJoe, 11 May 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Instagib
    Instagib Minimodder
    12 Mar 2010
    What is the bandwith like across the ExpressCard slot? is it comparable to a full fat 16*pci-e 2.0?
  3. flibblesan
    flibblesan Destroyer
    27 Jul 2005
    It's comparable to an x1 slot, if I remember right.
  4. JCBeastie
    JCBeastie What's a Dremel?
    10 Nov 2005
    Don't see any potential for this tbh, at least for people hoping to game.
    First you're limited by bandwidth, PCI-E 1x. Then you're limited to 80 watts of power, then by size of the case. All of this for more money than a supported graphics card would cost! It makes no sense.
    However it could be used for specialised cards, proffessional sound cards or TV etc...
  5. GiantStickMan
    GiantStickMan What's a Dremel?
    14 Feb 2010
    They aren't the first ones to try it. As a solution for gaming on a laptop with integrated graphics - it's a lot of money for very little benefit, the expresscard slot is a serious bottleneck to any potential performance.
    That being said there are other applications where it could prove quite useful.
  6. Icy EyeG
    Icy EyeG Controlled by Eyebrow Powers™
    23 Jul 2007
    It'll be interesting to see this product reaching the consumer market, as I remember that this was one of the supposed benefits of PCIe that was described when the technology came out: A PCIe docking station that can increase the connectivity and performance of a notebook.
    However, this approach comes a bit too late IMAO, as the bandwidth need is a lot greater nowadays than it was when PCIe was launched and therefore the ExpressCard connection is quite limited.
  7. blood69
    blood69 What's a Dremel?
    23 Sep 2009
    Only crap, 400$??? and it can't support high range cards like 5870??
    Lets say i want to buy a laptop for 800$, it will have a medium range graphic card in it, so why spend more 400$ for one of these things, plus the price of the card itself, lets say 350$ for a medium high card.
    400+350+800=1550$.
    With 1550$ i can afford a good laptop with a good graphics capability, a good usage for this is in Netbooks because of its lack of graphics power.
    And if this one costs 400$ imagine how many $ they will charge for the 3 slots with more watts on it.
  8. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    3 more PCI-e slots hmmm.....
    More space for folding GPUs!! :D
  9. DeadMan
    DeadMan Betterer
    22 Jan 2002
    Doomed to fail, just like the Asus XG which never made the light of day.
  10. ripmax
    ripmax Minimodder
    8 Apr 2010
    Waste of money, would rather spend the money on a better laptop
  11. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    x1 Bandwidth might sound limited, but it's more than enough to get roughly 80% of the performance of most cards.
    Sheesh, you people sure need to read more (it has been covered) instead of spreading false-truths.
  12. GiantStickMan
    14 Feb 2010
    This is very much the same concept - it's interesting to read some of the limitations that were inherant in the device at the time - and probably still would be.
    http://www.tomshardware.com/reviews/vidock-expresscard-graphics,1933-2.html
    It's important to stress however, that this item is not just aimed at allowing you to use external graphics cards like the link above, as its benefits to run graphically intensive games would be very limited indeed.
    You'd be better off just buying a laptop with a decent graphics card to begin with.
  13. mclean007
    mclean007 Officious Bystander
    22 May 2003
    As a proposition to gamers, useless - ignoring the obvious limitations, for £267 you're not far off being able to buy a desktop PC (minus the GPU) for gaming, and keep the laptop for other tasks. Or take the cost of the caddy and the GPU and add £400 to your laptop buying power to get something with a competent discrete GPU.
    For specialist needs like the TV feed processing cited, much more interesting!
  14. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Do you have a source for this as I have read numerous different articles on pci-e bandwidth limitation but none of them have really looked in depth at the difference speeds across a broad spectrum of cards (the last one I read was GTX295 being bottlenecked massively once the slot dropped to 4x or below.
    Not exactly what I was after but backs up what I have seen before:
    http://www.techpowerup.com/reviews/AMD/HD_5870_PCI-Express_Scaling/7.html
    I assume the drop will still be quite severe on even something like a hd5670 just not as bad as your are seeing on the HD5870.
  15. sub routine
    sub routine Archie Gemel
    27 Sep 2007
    Desktop based gaming at home and unplugged a more fuel efficient and portable lappy. Nice idea at least.
  16. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    So, $400 for a external case with a mechanical x16 but electrical x1 slot? Ho hum. Add in the videocard, and you lose the perception of value. It's cheaper to sell your existing card, and just buy a new laptop.
  17. Passarinhuu
    Passarinhuu I huffs cats
    30 Jul 2007
    It's a great idea but with huge bootlenecks.
    If they get the price at around $100-150 and find a way to bypass the ExpressCard bandwidth limitation I would totally buy it.
    Is there any planned review of ExpressCard that allows x16 PCI-E?
  18. StudioRecorder
    StudioRecorder Mobo's need Fabo's for company!!!!!
    14 Jan 2010
    being someone who is very interested in pro audio equipment this looks like a pretty good product, as it will allow a studiograde interface with a lot of inputs be connected to a laptop (usb and firewire can only handle around 16in/4out) i wonder if this could allow you to run pro tools hd by using it to connect a required hdcore card?
    what are the dimensions for cards that will fit into this?
  19. cyrilthefish
    cyrilthefish What's a Dremel?
    15 Apr 2004
    I did look that up :)
    Looks like the next standard (expresscard 2.0) uses USB 3.0 and as far as i can work out, PCIe 2.0 (nowhere mentions lanes, so i'd assume PCIe v2.0 1x which is roughly equal in speed to PCIe v1.0 2x)
  20. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    So wait are you hooking up a monitor to the box or still using the laptop screen, I might have over read that part if it was answered or not?
Tags: Add Tags
