Networks network cables cat5 cat5e cat6
Discussion in 'Tech Support' started by Cus_de_Sparta65, 4 Jan 2013.
  1. Cus_de_Sparta65
    Cus_de_Sparta65 "There is no dremel"
    24 Apr 2009
    Hey guys, trying to hook up a new PC to my router via a wired connection. The router is working great with all my wireless devices but trying to set it up with a cable I am getting a "can;t find network adapter" message! I am not sure if I need drivers or not but the problem there is it is a Virgin Media Super Hub (yeah sure Richard!) and I think the drivers are downloaded automatically thru firmware updates. I am loathe to call their tech-support as trying to get a wee Indian guy to understand a thick Glasgow accent is extremely frustrating and soul destroying:wallbash: LOL
    I have a few ethernet cables, cat5 and cat5e I think they are. I have tried them all but getting the same message. When I plug them in, some get a green light next to the network port and some get a orange light, which color should it be when connected properly?I don't think the two problems are connected but thought I would ask since I'm here.
    Thanks, Cus:thumb:
  2. sniperdude
    sniperdude Minimodder
    8 Sep 2010
    you network cards drivers may not be installed or may have been disabled.
    open the device manager (windows key + pause/break or just type device manager in the search box)
    look for network adapter and if any have a red cross or a downward pointing arrow over them right click and enable them
    (saying all that above I have just checked my own and the reg light goes off when they're disabled
    you should use the cable that give the red light thats means is a gigabit connection.
  3. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    As above, if it's missing a driver it will be listed as an 'Other Device" in device manager. Just download it on another computer or use the setup disc for your board.
    Oh and off topic, the orange/green light you see will depend on cable used from the Superhub. If you're using standard CAT5 then you will see a green light (10/100Mbps). If you use CAT5E or above you will see an orange light (1 Gbps).
    Cus_de_Sparta65 likes this.
  4. Cus_de_Sparta65
    24 Apr 2009
    Thanks guys, up and running now. like you said I just had to get the drivers from the disc. I usually like to get the latest drivers from the company web site but I had no way way to save them on my laptop and then transfer them to here as my flash drive is kapooted.
    I do have a card reader but I am not sure where to plug it in to the Mobo
  5. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    +Rep you lovely man I didn't know this shortcut and it's a goodie.
  6. Nanosec
    Nanosec absit iniuria verbis
    28 Apr 2009
    have some more Rep.....I was also unaware of that lovely shortcut !!
  7. Unicorn
    25 Jul 2006
    Really? That's like not knowing how to open the run command with the Windows key and R! It's one of the first things I learned when I started repairing PCs :)
