Network connectivity
Discussion in 'Hardware' started by Guest-16, 30 May 2007.
What network connectivity do you use?
  1. One 10/100 Ethernet
    26 vote(s)
    54.2%
  2. Two 10/100 Ethernets
    4 vote(s)
    8.3%
  3. One Gigabit Ethernet
    15 vote(s)
    31.3%
  4. Dual Gigabit Ethernet
    9 vote(s)
    18.8%
  5. More than two Etherent sockets
    3 vote(s)
    6.3%
  6. 54g WiFi
    29 vote(s)
    60.4%
  7. 11b WiFi
    4 vote(s)
    8.3%
  8. Draft-n/other-n/other non standard WiFi
    6 vote(s)
    12.5%
Multiple votes are allowed.
  1. Guest-16
    Guest-16 Guest
    From a reviewer POV, I'm interested if people actually use more than one Gigabit Ethernet, or if it's actually just marketing fluff? I can certainly see the advantage of onboard WiFi, but do people ever use more than one Gigabit socket? Do people even use more than 10/100 at home?
    Let me know, it'll help just future boards I review :)
  2. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    I'm assuming you want the votes based on one computer rather than my entire network?
    On my rig:
    gigabit to my server
    100mbps to the network
    wifi for snooping around (copper pipes behind the computer leading to the loft acts as an antenna :D)
  3. capnPedro
    11 Apr 2007
    Onboard Ports
    Gigabit to a switch
    10/100 to a printer
    PCI Cards
    54Mb (g) WiFi (used at certain friends' LANs)
  4. GiGo
    GiGo was once a nerd.....
    12 May 2002
    Main Rig Dual Ethernet one goes to main network, one goes to the 'download pc' the router uses 54g and aint got any others on wireless yet, most of my other pcs use the onboard 100mpbs adapter as all they do is connect to the net.
  5. K.I.T.T.
    K.I.T.T. Hasselhoff™ Inside
    1 Jan 2005
    10/100 to webserver, fileserver, FSG-3 and my computer.
    54G to printer and anything thats not Pre-N enabled.
    Pre-N to anything thats enabled for it.
  6. Guest-16
    Guest-16 Guest
    So people DO use more than one Ethernet port. That's more than I realised! :eeek:
    EDIT to actually MAKE SENSE now. :rolleyes:
  7. culley
    culley What's a Dremel?
    12 Jul 2006
    10/100 to File server
    54g to internet
  8. Atomic
    Atomic Gerwaff
    6 May 2002
    Only machines I use with dual ethernet are servers...
  9. Glider
    Glider /dev/null
    2 Aug 2005
    Just choose 10/100 and 54g wireless because that's what I have atm. I used to also have a gateway/router with 5 NICs in it (WAN, LAN, DMZ, Wireless and mini cluster) but that got ditched.
  10. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    10/100 to router, that's it for my main rig. Only the laptop uses 802.11G (although I have used its network socket on occasion).
  11. Krikkit
    21 Jan 2003
    I'd use both my GB ethernets, but we're in rented houses and can't go routing 10/100/1000 cables about, so it's wireless B/G for internets and then 10/100/1000 for transfers that aren't USB2. :D
  12. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    10/100 here, only 'cos switches don't support GB. Pretty sure the house is wired for GB lan.
  13. Silver Shamrock
    Silver Shamrock What's a Dremel?
    19 Sep 2005
    I'm exactly the same. Even the bit in brakets :)
  14. kenco_uk
    28 Nov 2003
    11g to a wireless-ethernet converter with 4-port 10/100 hub built in, of which 2 are are in use :)
  15. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    this
  16. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    10/100 into the house network (all it needs is a gigabit switch, the wiring's already gigabit hardware), 56g on the laptop for school. When it's at home, I drop a router between my PC and the wall and jack the laptop into that.
  17. sheninat0r
    sheninat0r What's a Dremel?
    28 May 2007
    draft-n 2.0 Cheesecake!!
  18. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    dual gigabit for each of my 2 sig comps on a 12-port switch.
    my roommate has a laptop using gigabit (sony vaio docking station) and a 680i desktop I built for him using dual gigabit both on the switch as well.
