Linux Network Errors
Discussion in 'Software' started by LAGMonkey, 16 Apr 2009.
  1. LAGMonkey
    LAGMonkey Group 7 error
    4 Aug 2004
    Right, After a clean restart and a change of ethernet cables to my Cable modem im still getting network errors,
    my ifconfig is as follows, note the RX errors
    eth1 Link encap:Ethernet HWaddr 00:19:66:34:FE:B7
    inet addr:xx.xxx.xxx.xx Bcast:255.255.255.255 Mask:255.255.254.0
    UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
    RX packets:1408933 errors:13 dropped:18 overruns:5 frame:0
    TX packets:775367 errors:0 dropped:0 overruns:0 carrier:0
    collisions:0 txqueuelen:1000
    RX bytes:1538122328 (1.4 GiB) TX bytes:87991901 (83.9 MiB)
    Interrupt:201 Base address:0xa400
    The above is my 100meg ethernet onboard ethernet,
    01:05.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+
    If the trend continues as it did before, ill continue to get errors but i dont know what they could signify. Could it be the cable modem causing me problems?
    Any help would be appreciated, everything seems to be working but errors are errors, and its starting to bug the crap out of me.
    Simplified Network topology = linux router <----> cable modem <-----> internet
  2. LAGMonkey
    4 Aug 2004
    new cable attached to the modem and ive got the following after 3 days uptime...
    inet6 addr: fe80::219:66ff:fe34:feb7/64 Scope:Link
    RX packets:8490958 errors:65 dropped:215 overruns:22 frame:0
    TX packets:4828463 errors:0 dropped:0 overruns:0 carrier:0
    RX bytes:4025048665 (3.7 GiB) TX bytes:432520920 (412.4 MiB)
  3. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    is there any output in DMESG that looks out of the ordinary?
    LAGMonkey likes this.
  4. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    RX packets:8,490,958
    errors:65
    dropped:215
    overruns:22
    frame:0
    65 is 0.0007655202157400849% of 8,490,958
    215 is 0.0025321053289864347% of 8,490,958
    22 is 0.00025909914994279797% of 8,490,958
    I work in networking, have done for years now, and I would recommend that any fraction of a percent packet loss is definitely not going to impact you, and would be worth ignoring :)
    If however you're interested in resolving this nonetheless, I can give you this information. It may not be 100% accurate as I deal with Cisco, not Linux :)
    - Errors are frames which fail checksums
    - Dropped packets are usually due to input queues being overloaded
    - Overruns are usually buffer overruns
    The drops/overruns will usually coincide to a point. If they were clocking at a much higher rate I'd be inclined to say you're using more bandwidth than you've got, but since its such a minute level my general conclusion would be as per above: its well within tolerance, you won't see any visible effect, and should probably ignore it :D
  5. LAGMonkey
    4 Aug 2004
    plus points for zune as explaining what errors, drops and overruns mean, and i suppose you are correct, it isnt very significant at the moment so i guess i can ignore it.
    as for the DMESG...
    I hadnt throught of looking at that, so plus points for you too C-Sniper.
    There are quite a few unknown protocols in the DMESG so i can guess that the errors etc are related to that, ill update my L7-protocol definitions later on today after ive bung in the new hard-drive and memory.
  6. Zoon
    12 Mar 2001
    Yay points! You're welcome :)
