Networks network question
Discussion in 'Hardware' started by kazama, 20 Dec 2006.
  1. kazama
    kazama What's a Dremel?
    9 Dec 2006
    hi guys, i think this question have been asked by another user. but i didnt find the thread :sigh:
    the probs that confused me is, when i turn on the router, it will show that the connection is unlimited conectivity.
    why its happen and how to fix it.
  2. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    If its xp, right click the icon and click on Repair.
  3. kazama
    9 Dec 2006
    " limited or no conectivity
    you might not be able to access the internet or some network resources. this probs occured because the network did not assign the network address to the computer "
    but should i click repair after i turn on the router?. is there any method to assign the network address to my computer?
  4. jake
    jake Network Gawd
    24 Jun 2002
    It sounds like you're turning on the router after turning on the PC. environmentally frendly it may not be but routers are generally intended to be always on, then when your PC is turned on it requests an IP address via DHCP and the router assigns it one. if the router is off or still initialising at this point then it's going to fail.
    To get around it do one of two things - leave the router turned on or statically assign an address to your PC.
    J
  5. AJB2K3
    12 Dec 2005
    When the router has finished booting.
    As far as i gater all it does is delete the ip assignd by winows and requests an ip from the router.
    Nothing scary.
