Networks Network Win8 with Vista
Discussion in 'Tech Support' started by nichos, 20 Nov 2013.
  1. nichos
    nichos Minimodder
    17 Feb 2006
    Trying for ages without success yet.
    I networked for years my home XP machines.
    I read many help files how to but, could not make it work.
    Without doing anything to Vista laptop it can see all the Win8 drives & can read & transfer files there.
    My w8 win-explorer list shows under Network the VISTA LAPTOP. When I click on it says cannot access, please see attached.
    I believe I am Administrator as I carried out the info from this web site below. What else can I do?
    http://helpdeskgeek.com/windows-8/log-on-as-administrator-in-windows-8/
    Any help to get me networking from w8 will be appreciated?
  2. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    have you enabled file sharing?
  3. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    I will guess the Vista PC has no password on the account? You should make same username/password on all machines in network it will auto authenticate. Otherwise you need to go into the sharing settings and disable password protected sharing.
  4. nichos
    nichos Minimodder
    17 Feb 2006
    Thanx all,
    Yes enabled file sharing in w8, Vista & Acer XP.
    Both Vista & AcerXP see & Can work in w8 drives & files. W8 can not, although prints wirelessly .
    I thing I saw disabled passwords somewhere but in W8 there is no option in the sharing settings to disable password protected sharing.
    Where would it be in XP & Vista too?
    The other thing in W8 I found now is that if I change from Busines to Home networkin it does not stay even after reboot as per instruction, see attached.
  5. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    you'll probably need to turn off home groups on all the 7+ boxes, you're not part of a work network (no domain etc so keep it as a workspace), and once you've done those things you should be able to do \\server\share from all boxes. You'll need to share these with accounts that have passwords and when prompted just enter pcname\user and the pass.. then save it. Should be good
  6. nichos
    nichos Minimodder
    17 Feb 2006
    what is "all the 7+ boxes" ?.
    there is no domain or homegroup ticked anywhere, & sharing is.
    I am fearing that again I'll be chasing my own tail & coming to a dead end.
    Would this have anything to do with it? :-
  7. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    on the boxes running anything that has home groups (Vista, 7, 8, 8.1) turn them off.
    Also no- you can be connected to the wifi and the cable at the same time.
  8. nichos
    nichos Minimodder
    17 Feb 2006
    Thanx,
    home groups are turned off in the only 3 I have 8, vista & xp.
    What is the trouble with this ruddy thing, I tried everything I was told to do.
  9. nichos
    nichos Minimodder
    17 Feb 2006
    Also this below is from my Vista, can you discern anything blogging W8 seeing Vista files?
  10. law99
    law99 Custom User Title
    24 Sep 2009
    check firewall.
    Check:
    net use
    in cmd and see if there is a listing for your vista machine.
    So you are looking for \\LOUISE\* under remote. If it is listed type
    net use [path to remote] /delete
    That is the only thing I've ever happen to me. I'd saved bad details. Not sure how... but that is what I did.
    Probably a red herring...
  11. workingclass
    workingclass What's a Dremel?
    17 May 2010
    The machines need to be in the same workgroup.
    You need to have enabled sharing.
    You need to have a user and pass on machines you are trying to access, or provide permissions to accounts on other machines (Through permissions tab).
    If I remember correctly you would have to join a workgroup created by one of the computers. Should say somewhere "join workgroup". You will need to enter the generated password or a password of your choosing to join.
    Have you tried creating the workgroup on the 8 machine and joining from the XP one ?
  12. nichos
    nichos Minimodder
    17 Feb 2006
    Thanx,
    1. workgroup is set in machines, what do you meen be "same"?. Done the rest without passwords.
    2. not found in "net use"
  13. saspro
    saspro IT monkey
    23 Apr 2009
    Change the network type to home or work.
    If it's showing as public (like the picture shows it is) then filesharing won't work properly
  14. nichos
    nichos Minimodder
    17 Feb 2006
    Thanx,
    Vista has no homework, & I never used public, if I did by mistake please point it out.
  15. saspro
    saspro IT monkey
    23 Apr 2009
    As the Picture shows it's set to public I can only assume you've got a network error which is confusing Windows and enabling the firewall.
    Does it work if you turn the firewall off completely?
  16. law99
    24 Sep 2009
    to be fair, it does say it is public. As saspro says
  17. nichos
    nichos Minimodder
    17 Feb 2006
    I must be getting blind.
    Please point me to the place indicating PUBLIC............thanx
  18. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    the second little house where it says nichos (public network) at the end of that line it says customise, click that
  19. nichos
    nichos Minimodder
    17 Feb 2006
    Thanx, it was Vistas.s & corrected in net& sgare center with no result.
