Networks Network wiring and setup !
Discussion in 'Hardware' started by ComputerKing, 18 May 2007.
  1. ComputerKing
    8 Sep 2006
    hey , another question ..
    I know that , I can find in Google but I cant find the keywords to search . sorry
    I want to setup the network wire that plug in the computer or to the router ..I know there is tool but how I can use it and how I put the wire in the small male plug ..I don't have clue .. and the wire older ( orange . orange white ... etc ) I was know them but now forget them . there are 2 kind , First from router to PC , second kind from PC to PC .. but don't know how to setup them .. I was do this from 3 years and never done it from that time ..
    Any help , I want some photos or some thing . thanks very very much
  2. Glider
    Glider /dev/null
    2 Aug 2005
  3. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    The tool you want is a RJ45 Crimper. To use it you put the wires in the correct order for the head of the cable, then you slid it into a slot on the crimper and then just squeeze the handles.
  4. ComputerKing
    8 Sep 2006
    Thanks very much .. the photos is damm good !
    I tried it it worked , My dad netwrok wire was need to change this male plugs and I did it , yeahhhh
    thanks very much guys .. thanks
