Networks Networking Noob - Server advice needed
Discussion in 'Hardware' started by jetsetjimbo, 2 Jun 2003.
  1. jetsetjimbo
    jetsetjimbo Up-up and away
    19 Feb 2003
    OK, I've got a peer to peer network at home between a couple of XP and windows 98 machines.
    I really want to learn my way around client / server networks as I want to get into the IT industry an client server experience seems pretty important.
    I'm buying a new box to act as a server... what I want to know is how should I go about it, what OS should I use, will I need the same OS on all machines? Will it slow down the other machines?
    I have a stack of other questions as to what I can use the server for and the best way to go about it but I'll save them for a bit....
    BTW - I am currently sharing an ADSL connection with a router.
    Thanks, any help would be greatly appreciated! I am ready an willing to learn :)
  2. herbs
    herbs Nobody but us chickens
    7 May 2001
    Your best bet if you want to get into the industry is to install windows 2k server (or maybe 2003 server) and play around with it. Alternatively you could try BSD unixes or linux, a harder learning curve but you get a better understanding of how things work.
    Personally I would do 2k server with your own clients mixed with windows, this way you can see how different services are provided to different clients. Such as how win9x/me clients don't use ADS, whereas 2k and XP PRO clients do. Also make sure everything is patched and tied down if you are giving them internet access.
  3. jetsetjimbo
    19 Feb 2003
    Cheers Herbs, I take it with Patched / Tied down you mean install all the latest patches and firewalls?
    Is 2k server hard to set up, I've done my A+ but am wondering if there's a good source of info online for getting started....
  4. andyunder
    andyunder What's a Dremel?
    22 Mar 2003
    2k server is easy to set up its nearlly the same as xp. if you have done you a+ you should do the network+ too as you will learn every thing about 2k pro on peer to peer and 2k server on client/server
  5. jetsetjimbo
    19 Feb 2003
    Cheers andy, I reckon I might just do that! - Is it pretty straight forward to set up all the admin stuff in 2k server?
  6. Atomic
    Atomic Gerwaff
    6 May 2002
    Basic access rights/privilages are easy, but it depends how deep you want to go.
  7. andyunder
    22 Mar 2003
    yep it sets the admin acount for you then its just a matter of working out how to add users if you need help doing that just send me a message
    edit: access rights are easyer in 2k than nt4 as that is what atomic has been using he would find it easier in 2k
  8. jetsetjimbo
    19 Feb 2003
    Thanks andy, really just want to sort out logging into the server for a couple of different accounts with various levels of access to begin with. Do you need to set up each individual client (machine) or just the accounts to login with?
  9. Atomic
    Atomic Gerwaff
    6 May 2002
    :grr: darn you... im happy with it anyway.
  10. andyunder
    22 Mar 2003
    you set up the users on the server then set the client machines to log it to the server so you will have to use a domain instead of a workgroup. that can be done in 98 and xp pro so if you have xp home you will need to upgrade
  11. jetsetjimbo
    19 Feb 2003
  12. andyunder
    22 Mar 2003
    i presume they mean 900mhz
    it does not sound too bad but depends on what you want to use your server for. it is also running linux so unless you can already use linux i would not advise it to start off with
  13. jetsetjimbo
    19 Feb 2003
    That's what I thought but it looks quite cool, I'm going to try an get into Linux slowly. Would a server like that just be used for email, ftp, web server....?
  14. andyunder
    22 Mar 2003
    sorry cant help you with linux as can only just use it my self but i do you that you can use ias a ftp/web/email server
  15. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    Sounds like it is running something akin to e-smith (http://www.e-smith.org).
    Personaly, I'm going the Linux server route, because it is free :thumb:
    If I had the money, I'd do Windows, though ;)
  16. counterclockwise
    counterclockwise What's a Dremel?
    17 May 2003
    win servers are evil compared to linux/unix, i mean servers are one of the things linux is best at - all that stability and security.
    even if i had the money for windoze servers i'd definately use linux
  17. andyunder
    22 Mar 2003
    i agree linux/unix serves are better but for a noob to servers i think that windows would be better to understand how they work
  18. jetsetjimbo
    19 Feb 2003
    I think I'm going to go with windows for now, any pointers for getting gently into Linux would be gratefully accepted. :)
  19. counterclockwise
    17 May 2003
    get a coppy of knoppix and play around witnh it - it's a distro that runs straight off the cd, so you don't need to install it (althougth you can). The bast way to learn is to play with it =)
  20. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    2k is basically limitless for server use, you just need some good hardware, as my server at the moment is (believe it or not) a P133 with 48 mb RAM, running 2k pro - below spec. The actual response time is great, and it does a good job of serving ADSL through a usb modem (it has an early abit mobo with one SD slot and a usb header). But it took four tries to install without crashing :D
    (by the way, uptime is about a month and counting)
