Networks Networking question
Discussion in 'Hardware' started by CursedBlad3, 6 Jul 2006.
  1. CursedBlad3
    CursedBlad3 What's a Dremel?
    30 Jun 2006
    Im not very experienced with networking so sorry for the noobish question...
    Is it possible have a setup similar to the following..
    Modem
    Router
    Switch
    PC PC PC
    or would it have to be
    Modem
    Switch
    Switch
    PC PC PC
  2. wharrad
    wharrad What's a Dremel?
    26 Jul 2003
    Top one's the puppy.
    Look out for a modem with routers built in, they're pretty common and then it'd be...
    modem & router
    Switch
    PC
    And some of these modem/routers have 4 ports (built in switch too) which might help...
    Modem/Router/Switch
    PC
  3. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    Yup, as has been said the top one is key. You may not find a modem/router/switch, cause they are some what more expensive, but atleast try to get a router with builtin switch.
  4. Glider
    Glider /dev/null
    2 Aug 2005
    I actually like the modem and the router/switch to be separate... But that's just personal preference...
  5. CaseyBlackburn
    27 Jul 2004
    Plus it is cheaper to replace if something goes wrong, and easier to determine what is the problem.
  6. DougEdey
    5 Jul 2005
    If you're on Cable it'll be:
    Modem -> Router/Switch --> PC
    I've yet to see a cable Router which does not have a switch
  7. Glider
    Glider /dev/null
    2 Aug 2005
    And if your on ADSL it goes: Modem -> Router/Switch -> PCs ;)
  8. CaseyBlackburn
    27 Jul 2004
    And if you are a WISP, it goes: Wireless Receiver -> Router/Switch -> PCs. (Not that you would have a WISP unless you live out in nowhere.)
  9. wsurritte
    wsurritte What's a Dremel?
    31 Oct 2005
    some ADSL modems have a router built in.
  10. CursedBlad3
    30 Jun 2006
    yea but my network cable is quite long, my pc is upstairs.. and the router and modem are downstairs and i was wondering if i could just throw a switch in on my end
  11. wharrad
    26 Jul 2003
    yeah, easy as that.
  12. CaseyBlackburn
    27 Jul 2004
    Yes ofcourse you could.
  13. CursedBlad3
    30 Jun 2006
    ok thanks, sorry i dont know alot about it and figured you guys were the best to help :)
  14. wharrad
    26 Jul 2003
    No Problem, I'd have nothing to do if people didn't ask stuff
  15. Glider
    Glider /dev/null
    2 Aug 2005
