Build Advice New £2k system, advice?
Discussion in 'Hardware' started by sunny304, 16 Aug 2009.
  1. sunny304
    sunny304 What's a Dremel?
    27 Jun 2009
    Ive been looking around for about a month now, and was initially planing on building something close to 1000 next month but ive now decided to spend the next 4 months building something closer to 2000, and future proofing
    So my plan is once built, the cpu will be overclocked to 4ghz, or close too
    I eventually plan to watercool it, not until maybe january/february
    The crossfire gpus may or may not happen, depending on the progress dx11 cards
    Just wondering if anyone can offer any further advice on the system specs ive given below
    Case - Lian Li x1000 - 300.00(something like this ?) When its available
    Motherboard - Asus P6T7 WS Revolution - 339.25
    Power Supply - 1250w Enermax Revolution - 217.35
    CPU - Core i7 920 2.66Ghz - 201.45
    GPU - Sapphire 4870x2 x2 Crossfire - 243.46 Each
    RAM - 6GB Corsair Dominator GT 2000mhz - 235.98
    CPU Cooler - Thermallight Ultra Extreme 120 - 51.62
    Hard Drives - 1TB Samsung Spinpoint F1 - 113.86 - Media
    500Gb Western Digital - Currently Own - Backup
    300GB VelociRaptor 10000rpm - 165.39 - Games
    32GB Corsair Extreme Series - 114.22 - OS
    Total - 2226.04
    Thanks
  2. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Drop the Quad XFire this second, it doesn't scale well and its major overkill anyway, I am assuming the Velocirptor is for a balance of speed and storage
    for £2000, upgrade from the 920 to 950 and drop one 4870X2 or even both and go for a 4890X2 set up, Power Supply is overkill, the motherboard is kinda overkill, mate are you gaming or simulating a nuclear bomb on Moscow in Real time?
  3. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    A velociraptor? In this day and age?
    We need a SSD expert here stat!
  4. sunny304
    27 Jun 2009
    lol
    ill drop one of the 4870's, and go to the 950
    the reason for the motherboard, was to utilize 2000mhz ram speeds or to basically future proof, i dont want to buy new board next year again for another 200 quid, which is what i seem to be doing year in year out
    the power supply again was to future proof, but ill drop it down 850 or 950
    anything else you reckon ?
  5. sunny304
    27 Jun 2009
    SSD's are still expensive, ill be buying it at the tail end so perhaps we'll see a drop in price
    if so, ill replace the velociraptor
  6. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Indeed and he is using an SSD for Boot Drive, the Velociraptor is very fast (if not as fast as SSD) and also has reasonably storage - 300GB = 30 Games
  7. Krikkit
    21 Jan 2003
    Meh. Buy a bigger SSD and just uninstall a game once in a while.
    There's really no point in a Raptor atm. If you really want a fast place for putting games that isn't an SSD just buy a Spinpoint F1.
    Also, whatever the outcome, get a 60GB SSD. An OS with a few programs will fill up 30GB pretty quickly, even without games. A 60GB G.Skill Falcon drive is only ~£150.
  8. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    DX11 cards are about to come out (Q4 this year), as well as Nehalem.
    I wouldn't advise upgrading until they're out to be honest. :)
  9. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    +1 on Krikkit.
    Or a 60Gb SSD for the OS, another HDD for the programs/games (Spinpoint F1 1Tb) and have the 500Gb for files?
    With the money you save from only having a 4870x2 instead of two of them, build an Atom system with a 1.5Tb HDD as backup, or even better, as a RAID 1 file server (with just the SSD in the case).
    As for the PSU a Seasonic M12D 850 might be worth looking into, should power the thing with no problems and save you about £50 in the process.
    Though before any upgrades, wait about a month... With DX11 cards coming out soon the price of a 4870x2 will plummet, and with Nehalem the same should happen with the i7 chip.
  10. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Changes
    Replaced your case with a cheaper but equally desirable one from Lian Li,
    Velociraptor was replace with an equally fast Samsung Spinpoint F1 for Games, 1TB Storage Drive and 64GB SSD from Corsair for boot/programs, BeQuiet Dark Pro is cheaper than Enermax and better - The Motherboard still accepts 2000MHz RAM but its half the price
    What do you think - it's at £1700
    Or you could indeed wait for DX11 and i5/i9
    EDIT: The picture doesn't seem to show
    EDIT: link is here: http://tinypic.com/usermedia.php?uo=bXcZ8DDMLuR923/tRP3Saoh4l5k2TGxc
  11. sunny304
    27 Jun 2009
    well im gonna buy in the order of
    case
    psu
    mobo
    ram
    the later items such as cpu and gpu will come in november december
    so that should leave enough time for the intial dx11 cards out in october
    nehalem ? this architecture is already in use, all i7 cpu's use this
    the only upcoming advances in cpu's are the apparent i9, which isnt scheduled until q2 2010
    so buying an i7 950 isn't really a bad idea just now
    unless im not up on something, which is probably true :p
  12. Solidus
    Solidus Superhuman
    26 Dec 2005
    I spent about £2000 + on a pc build a couple of years ago....
    My advice? put it towards a cheaper laptop that will do and put the rest towards a car.
    I wish I kept the money now in all honesty.....
  13. Krikkit
    21 Jan 2003
    Your tinypic doesn't work because you've pasted a link to a webpage, not a picture. :)
  14. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    tbh I agree with this, spend no more than £1000 on a computer, keep it for 2 years and maybe spend the other £1000 on something nice, computers depreciate too fast to spend £2000 on
    EDIT: or spend the £1000 on the stuff you don't change for a long time - TFTs, Peripherals, a case, PSU etc... all the things you won't NEED to change for 3-4 years or longer
  15. sunny304
    27 Jun 2009
    the cheaper the better, the drive idea sounds perfect, ill just ditch the velociraptor and use the extra funds for the 64gb ssd
    ill go with the dark power pro 850w instead, save me some money :p
    what board was it ? cant see the photo unfortunately
    as far as i knew i5 wont be as powerful as the i7 series, and i9 isnt until next year, near summer, or has this changed ?
  16. sunny304
    27 Jun 2009
    meh, if i were to just keep it, id only spend it on crap i didnt need
    its free money as im a student so i might as well get something wit it
  17. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    You could donate it to a... worthy cause - Moyo2k's Kickass Rig Mark 2 fund :p
    No but seriously - spend £1000 on a folding rig - if you've got spare cash its the most ethical thing you can do short of donating to charity
  18. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    Drop the 2ghz, just get a good 1.6ghz kit it's not worth the cash and 1.6GHz will future proof just as well as the 2GHz as by the time you need 2GHz for a good computing experience 6GB will only be just enough :)
    Also get a 60GB OCZ Vertex. Can use it as a multiboot that way. Also why do you need the Revolution? What's wrong with the deluxe V2? And why the hell are you paying over £100 for a 1TB spinpoint? That's awful. You can get it for around £70 or the WD Caviar Black 1TB for aroud that too. I wouldn't bother going for the enermax 1250w, get the 1050w, cheaper and 4 gtx 295's folding only require 1kw ish
  19. sunny304
    27 Jun 2009
    lol i never said it was spare :p
    just that i wanted to get something with my money instead of wasting it away
  20. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    I think the best thing to do is build a £1000 rig including screen and keyboard/mouse etc... the works and spend £1000 on a folding rig, I'd love to help you do that, £2000 gaming rigs are absolute overkill, would you like to do that?
