Apple New 15" Macbook Pro with 2880x1800 res
Discussion in 'Hardware' started by Picarro, 11 Jun 2012.
  1. faugusztin
    11 Aug 2008
    Yes, it is running at 1440x900.
  2. bagman
    bagman Minimodder
    18 Apr 2009
    Not surprising as asus have got 13" ultra books with full HD IPS screens.
  3. wyx087
    wyx087 Multimodder
    15 Aug 2007
    in that case, it's really not that much of screen space to be honest. it would even be a step down for those 1920x1200 MBP users.
    might as well buy the Air IMO, same screen real estate, but more practical as a portable computer.
    edit: 1920x1200 15inch and 17inch are gone!
  4. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    Like with the iPhone, the tech behind the display will be slightly different than people are used to. it will still "look" liek a 1440x900 screen (or proabably rather 1400x900), but apps that support it will upscale to 2800x1800 and increase in crispness.
    Apps not specifically made for the iPhone 4's retina display also work without having a half-sized logo, don't they?
    It's the biggest hurdle for Samsung, for example, that they can match the resolution of the iPhone screen, but not the pixel density without compromising useability. The tech used is different there, and that will eb the case for this screen as well.
    Bottom line: That 15" MBP with retina display looks like an amazing piece of kit:
    Ivy Bridge @ 2.3GHz + Turbo Boost (out of the box OC that on the 2.7GHz flagship makes it jump to 3.7GHz), 8GB RAM, 2x Thunderbolt, HDMI, SD Card, WiFi N, 256GB SSD, USB3.
    All of that at half a kilo less than the previous one (and 6mm less height) sounds VERY appealing to me...
  5. wyx087
    wyx087 Multimodder
    15 Aug 2007
    am i seeing this correctly? reporters using ipad to take photos??!?
  6. stonedsurd
    11 Mar 2009
    Probably got one device to liveblog from, taking pictures and pushing them along with text is better than juggling five devices.
    Pretty cool, actually.
  7. Cei
    Cei pew pew pew
    22 Mar 2008
    http://www.anandtech.com/show/5996/how-the-retina-display-macbook-pro-handles-scaling
    http://www.anandtech.com/show/5998/macbook-pro-retina-display-analysis
    Basically, it's awesome.
    Default mode is, as suspected, 1440x900 that is pixel-doubled. However, scaling works at multiple resolutions up to 1920x1200 (which matches the now-defunct 17" MBP). No 2880x1800. However, to bypass quality issues, it looks like Apple are doing crazy things.
    If you want to run at 1920x1200, the desktop is rendered internally at 3840x2400 (pixel doubling, best quality) and only then is it scaled. Equally, switching is very fast, so I can see people actually changing scaling depending upon task.
    Not only that, the cover glass is gone, the panel is IPS and glare is down.
    Gaming reveals the full 2880x1800 resolution. However, if not updated, tiny tiny text ensues.
  8. rollo
    rollo Modder
    16 May 2008
    Dout we will see this on other laptops Due to apple buying the supply of all retina panels for the future
  9. Taniniver
    Taniniver Minimodder
    24 Aug 2010
    The AnandTech "Display Analysis" article if anything confirms my fears rather than allays them - look at the screenshot comparing Chrome (not updated for new display, using scaling) to Safari (updated for the new display).
    @Guinevere, yes, I certainly recognise Apple has done a lot of work towards the transition, but only Apple have. I don't buy their products, I'm only interested in this display technology for when it makes it into standard monitors that I will be able to use on Windows.
    The work they had done is a reasonable interim workaround, but it is just that - a stop gap compared to proper support in applications. Taking an existing application and simply turning each pixel into a 2x2 grid of pixels isn't going to enhance the quality at all, it's just a way to get around the "tiny tiny text" problem.
  10. BentAnat
    26 Jun 2008
    True, but the bottom line is that all the big applications will start supporting the retina display. This will include Chrome, the Adobe Suite, etc. They all adapted to Retina displays on the iPhonce/iPad as well...
  11. Cei
    Cei pew pew pew
    22 Mar 2008
    Simply put, that is the developer's problem, not Apple. Apple have provided the technology and a best-attempt workaround for non-supported apps, but the onus is on developers to update their software. HiDPI is going to be the next thing on the block, and they need to bake in support.
    Why should Apple be castigated for pushing hardware? Everything starts somewhere.
  12. Taniniver
    24 Aug 2010
    I agree, and it wasn't my intention to castigate Apple for introducing it - quite the opposite, I welcome new higher resolution displays.
    I was simply pointing out that there is a lot of work to be done by the industry in general to properly support them. Legacy applications, video standards and most significantly graphics power are all going to need significant work/improvement before they become suitable for general use, at least for Windows users - it seems Apple have a definite lead on that first point at the moment.
  13. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    The ability to have more real estate as an option is of course great, but how it looks at 1920x1200 we'll have to see. The biggest issue with the HiDPI displays is that you either increase the resolution without gaining real estate, or you stick in a really high resolution "standard" DPI panel. The solution to all these problems would be to increase the HiDPI resolution even more, but the cost to do so is :waah:
    Must say, however, that I think the HiDPI displays are a must with mobile devices. wuyanxu, I really don't know how you have found there isn't much difference between the 3GS and the 4, as small text on the former was completely unreadable!
  14. wyx087
    wyx087 Multimodder
    15 Aug 2007
    perhaps my eye sight is going, i always zoom right in. or used the reader feature whenever possible.
    yes tiny text was unreadable on 3GS but neither are they on 4 unless my nose is touching the screen.
  15. Mac_Trekkie
    Mac_Trekkie Source Engine's #1 fan!
    10 Sep 2011
    that sheds some magnificent blinding white light on the situation. I give it about a week after they start getting to users before 2880x1800 can be selected for normal desktop use. As far as application support, give it a couple months. I'm impressed that he was able to get 20 fps in a relatively intense scene in Diablo III. I don't know how optimized that game is for Mac, but it still shows that the GT 650 has some grunt. Once again, the biggest downside comes down to storage space. If they only offered 512, or maybe 368 as an option for the base model, I wouldn't have any problems. As it is, I'll have to see whether or not cheapish fast and convenient Thunderbolt storage solutions have arrived by the time I have the money.
  16. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    For looks or performance? Because I personally would and have gone for the Asus g75 and 73 previous to that, but that is performance, they look ok
    Sent from my HTC Sensation using Tapatalk 2
  17. Cei
    Cei pew pew pew
    22 Mar 2008
    Okay, I just bought the bottom model, so I can let you all know how it is...once it ships in 2-3 weeks! Now need to offload the Air.
  18. Mac_Trekkie
    10 Sep 2011
    I think it's more for feel than either. Looks probably play a part into it, and the performance is fairly average, as GPU power goes, but the feel is probably beyond the current G series. I know that my old '09 MBP feels way better than a friend's '10 G series, in terms of build quality, trackpad and keyboard, sturdiness, weight, and that's disregarding the OS entirely.
  19. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Am I reading this correctly apple can not manage to force scaling for DPI set char in the system level...... you know like DOS.
    Please tell me I read that wrong.
  20. Virus44
    Virus44 What's a Dremel?
    2 Nov 2011
    apple still trying to sell their gimmicky displays of to their oblivious fans ?
