As the title says I want to go £500 max but I am willing to go lower if it is "good enough", I want the TV for Console Gaming & TV/Films, has around 4 HDMI ports (eventually want to hook up a PS4, XB1 and Wii U) and don't care about 3D, Wi-Fi services and that kind of stuff. I am looking at the 32 inch Sony W7 KDL-32W705B which while its 42 inch bigger brother has very low input lag and great picture: http://www.hdtvtest.co.uk/news/kdl42w705b-201402233639.htm, I was wondering if the smaller 32 inch brother has around the same amount of input lag. I was wondering if there was any other recommendations that anyone else had in mind. Any help?
I don't know where you are located but richer sounds always has some really good stuff on clearance, like ex display or eol. http://www.richersounds.com/clearance Sent from my Nexus 7 using Tapatalk
See if you can find a KDLW42653A around still as they should be £500. It's last years model of the same screen and means you can jump up to 42 - hardly any diferences; cosmetic, another few inputs, etc. If you're really lucky you can do what I did at Argos yesterday which is order their last KDLW42653A and run away quickly when they gave me the KDL42W705B instead!
Didn't we do something similar not so long ago? http://forums.bit-tech.net/showthread.php?t=268217 Different budget but the advice here is still good.
