News New 6-core AMD CPUs overclock to 4GHz on air
Discussion in 'Article Discussion' started by Sifter3000, 14 Apr 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. shokwaav
    shokwaav What's a Dremel?
    7 Apr 2010
    wow air cooling? amd's getting good............................
  3. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Its also worth pointing out that when Scan added the 6 core 2.8GHz Thurban, it was only £165. Even if you could only overclock to 3.5GHz on air, thats still a lot of processing power at a decent price.
  4. Nikols
    Nikols What's a Dremel?
    13 Oct 2009
    Eagerly anticipating the release of the 1090T BE. Had decided to upgrade my chip about 2 months ago to a phenom 965 seeing as they are so cheap and achieve 4ghz on air, then the news arrived that these would be release on April 26th and won't be costing an arm and a leg so I thought I'd hold out. I'll be running the chip on an asus m4a79 deluxe 790fx motherboard (updated the bios last week to take the new chips) but if bit-tech wants to swap an 890fx board for this I'd be very appreciative???? ;-)
  5. Unknownsock
    Unknownsock What's a Dremel?
    13 Jul 2009
    Even if the App takes advantage of these, ive heard that these still only perform similiar to an I7?
  6. Nikols
    13 Oct 2009
    Same price range, so is that a bad thing? For amd users it's great to have a similar spec (performance wise) option rather than taking a general performance hit by opting for an amd system.
    I think this chip represents a good "stop the rot" move from amd. Anybody considering an upgrade who read reviews were only really left with one option until now, intel. AMD chips weren't the best at multitasking and hopefully this will improve their reputation in the area. Now people wanting to upgrade will have two hopefully similar options and for those of us already on amd platform the cost is minimal. Therefore amd will retain more customers until the release of bulldozer
  7. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    It really depends on the core architecture though. Fine they have 6 cores but if software doesn't use them properly (even multithreaded apps seem not to benefit too much from the extra 2 cores) then it really comes down to the workload each core can do and core for core I think Intel is still miles ahead.
    I do think this has a whiff of the old MHz days though. 'Your CPU has 4 cores, but mine has 6 with go faster stripes...'. I also hope that these will bring the prices of current CPUs down and not just replace them. I hope Dual-Core and older Quads just become better priced rather than obsolete.
  8. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    At long last AMD finally gets a chip which can compete with Intel in the top end! After months of domination by the i7 series, some challengers should result in better pricing!
  9. UncertainGod
    UncertainGod Minimodder
    18 Oct 2007
    What's up with the 12-core link requiring a username & password?
  10. SazBard
    SazBard 10 PRINT "C64 FTW"
    28 Apr 2009
    Hmmm, what's the PPD of these things?
  11. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    Is the opteron link supposed to link to a top secret beta password protected version of bit?
  12. cyrilthefish
    cyrilthefish What's a Dremel?
    15 Apr 2004
  13. Sifter3000
    11 Jul 2006
    Oops, thanks, fixed!
    Yes, it's the beta version of the new version of the site :)
  14. dec
    dec [blank space]
    10 Jan 2009
    +1.
    Any word on what it can get with water?
  15. UncertainGod
    18 Oct 2007
    Having just proved my error spotting ability I think I deserve said beta access.
  16. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    WOOT WOOOT WOOOOOOT
    Thank you AMD, keep it up. :)
    So I havent read up on these yet, so if someone could give a basic break down for these CPUs
    What Socket are they?
    Do they have any backwards compatibility?
    Like I have an ASUS M3A79-T Deluxe motherboard would be nice to keep using it but if not understandable just pinching pennies where I can lol.
  17. TSR2
    TSR2 What's a Dremel?
    19 Aug 2009
    @HourBeforeDawn: Yes, can I stick one in an AM2 motherboard? Please, please xD
  18. Initialised
    Initialised What's a Dremel?
    23 Jul 2009
    ASUS have released BIOS updates for their full range of AM2+ and AM3 boards, even the nVidia variants. AM2 might be asking too much.
    Please be good journalists and quote your source: The source of the data http://forum.coolaler.com/showpost.php?p=2601846&postcount=25
    Glad you like the cooler, just like a Nordwand but half the price. ;)
    I know someone this side of the world has been running HT 243 for 3.4GHz on a 14x locked CPU with a stock cooler. So that blows a hole in the 230MHz wall. That board usually tops out around 260-275MHz on Deneb and Propus so 3.85GHz looks like the theoretical limit for low end boards, but like i7 980x the extra cores will increase the strain on the VRMs so even if you watercool you should make sure there is plenty of airflow around the VRMs especially on boards without VRM heatsinks.
  19. stonedsurd
    11 Mar 2009
    To be honest, I don't see the big deal. Clock for clock and core for core, AMD is yet to compete with Nehalem. So what does a 4GHz+ overclock do? Get them to performance parity with a 3-point-something GHz Core i7?
    EDIT: Just to clarify, I'm talking about benchmarks. Yes, for gaming, there's little difference, so don't go biting my head off just yet.
  20. Guest-16
    Guest-16 Guest
    That was not my source of data, I talked to motherboard companies working on their 890FX. ;)
    stonedsurd - for the odd applications that are in need of particular core features, rather than sharing through HyperThreading, the 6-cores will actually be faster. Check our recent 12-core AMD review ;)
Tags: Add Tags
