Case Mod - Complete NEW Antec P120 build fully watercooled
Discussion in 'Project Logs' started by AML_customs_pc, 2 Dec 2019.
  1. AML_customs_pc
    AML_customs_pc Minimodder
    24 Feb 2017
    Hey everyone, I am back with a quick build log.
    Antec asked if I could do a build in their new P120 case and this is my journey.
    The parts I will be using are,
    CPU - AMD 2700x
    GPU - ASUS Dual RTX 2080
    RAM - 16gb 3200 mhz Thermaltake WaterRam without the waterblock
    Motherboard - ASUS ROG Strix X470 - F
    Storage - Adata SX6000 256GB M.2
    PSU - Antec 650W high current gamer HCG
    Fans - Antec Prizm 120 ARGB
    All the water cooling parts were supply by thermaltake and I manufactured a custom distro with integrated ddc pump for this build.
    This is the case.
    I stripped the full case down and drilled all the rivets out as I want to paint the full case a gloss black with red splash. this would be the biggest part of the build.
    Before,
    After,
    Once the painting was completed I needed to test fit all the parts and plan the loop and get the holes for the front distro.
    This will be my 1st build where I will be using a DDC pump in the distro plate, I was not 100% sure on how to do this but a did find a guide on the bit-tech youtube channel which helped a lot thanks Alex.
    This is my design for the front distro.
    Now time to cut the part.
  2. AML_customs_pc
    24 Feb 2017
  3. xoltrix2000
    xoltrix2000 What's a Dremel?
    25 Sep 2009
    First of all, what is sick. You're work is amazing man.
    Question about the waterway/distro size. What is the exact size that made it fit perfectly?
  4. AML_customs_pc
    24 Feb 2017
    hey thanks, not sure on what sizes you want, I made a custom bracket to attached the distro to the front.
