Build Advice New Build £800 Max
Discussion in 'Hardware' started by mowlio, 15 Mar 2010.
  1. mowlio
    mowlio What's a Dremel?
    15 Mar 2010
    Budget: £700 - £800
    Main uses of intended build: Gaming
    Parts required: Everything
    Storage requirements: 1tb
    Will you be overclocking: no (but might if i can)
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): Nothing specific, although a nice soundcard would be cool
    Hopefully not a repost, only saw the list after posting one originally. Been out of the loop for a while and have no idea what's on the market anymore so some help would be errrrr.... helpful Thanks!
  2. mowlio
    15 Mar 2010
    Have been recommended Intel Core 2 Quad Q9550 Yorkfield 2.83GHz does this sound right? or should i opt for a i5 or i7 for gaming?
  3. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    What? Truly terrible recommendation for an £800 computer; socket 775 is dead, gone, obsolete - you do NOT want to put money into a system based around that CPU. If gaming is your thing, you're looking at an i5 750/i7 860 (i.e., a 1156-socket quad-core) with as powerful a graphics card as the budget will allow. Have a look here and here for component ideas. My suggestion would be;
    Core i5 750
    Gelid Tranquillo
    Gigabyte GA-P55M-UD2
    Corsair 4GB (2x2GB) Dual Channel 1600Mhz CAS 8 DDR3
    ATi Radeon HD 5850
    Samsung SpinPoint F3 1TB
    Corsair HX650W
    ATX-chassis - Cases are a personal choice so choose one and we'll let you know if it's a disaster. Good brands include Lian Li, Antec, Fractal Design - something in the £80-100 range should be suitable.
    Optical Drive - These are all the same, just pick a good brand.
    Regarding soundcards, I'm no expert but the UD2 comes with excellent on-board sound, as do most mid-high-end motherboards these days. I'm not sure you need one.
    Baz likes this.
  4. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    Puresilver said what needed to be said but about the cooler, it's a brilliant cooler but only available AFAIK from 2 places in the UK, Overclockers (which everyone will recommend you against) and Scan but it's out of stock at Scan and I emailed them today because I want one and they said they're awaiting confirmation from Gelid that they've sent another shipment of tranquillo's so you might need to wait a few days before being able to get your hand on it. Just thought I'd mention that.
    As for the power supply Custom PC recommend the Antec Truepower TP-650 and gave it a premium grade award it's also £15 cheaper than the corsair http://www.scan.co.uk/Products/650W-Antec-Truepower-New-PSU-Modular-120mm-PWM-Fan-80plus-Bronze :thumb:
    Sloth likes this.
  5. Digi
    Digi The not-so-funny Cockney
    23 Nov 2009
