Cases New Build/Case Debate
Discussion in 'Hardware' started by escafoxx, 24 May 2010.
  1. escafoxx
    escafoxx What's a Dremel?
    19 May 2010
    I've recently considered building a new pc and am now in two minds about a suitible case for it
    I'm aiming for a Core i3-530 build, along with overclocking it
    I'm on abit of a budget, so looking into other "cheap and cheerful" builds they tend to via for the SilverStone PS02B Case but looks wise it doesn't fit my aesthetic need (picky as it sounds, but that silver plate on the front bothers me)
    I'm looking for something solid black, pref with the PSU bay favouring the bottom. A fan slot in the front along with the roof would be a big plus too. Sticking with the budget, absolute max price I'd be willing to go to is £50
  2. seanbean
    seanbean Certa Cito
    21 Apr 2010
    Have you had a look at the Coolermaster Gladiator 600? YouTube. Seems to fit your bill/specs and, in my opinion, a smart looking case. £50 here
  3. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Antec 300 possibly?
  4. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    For that budget it has to be the Antec 300.
  5. LithiumDesign
    LithiumDesign 3dsMax User
    23 Jul 2009
    Antec 300, no questions.
    /thread.
  6. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
  7. Marine-RX179
    Marine-RX179 What's a Dremel?
    24 May 2010
    Well, Antec 300 only comes with rear and top fan, so would need to get 1 or 2 120mm fan for front as well as one for side-panel. But I guess that's optional however I think at least 1 front fan would definitely needed.
  8. Fingers66
    30 Apr 2010
    Agreed. A couple of Silent Eagles in the front and you will be sorted I reckon.
  9. EdwardTeach
    EdwardTeach What's a Dremel?
    3 May 2010
    Antec 300
  10. ripmax
    ripmax Minimodder
    8 Apr 2010
    Anything but the Antec 300 (I like to be different)
  11. Fingers66
    30 Apr 2010
  12. Pookeyhead
    30 Jan 2004
    That looks immense value. It looks lovely, and... well... I'd prefer that over a Antec300.
    It appears to not come with fans though, so it may end up more than £7 extra.
    Just work a bit harder and get that IMO. Who cares if Sharkoon sounds utterly stupid... just remove the name badge :)
  13. Fingers66
    30 Apr 2010
    Takes 5 fans, comes with 1 apparently - 1 x front, 2 x side, 1 x back and 1 x top.
    http://www.sharkoon.com/html/produkte/pc_gehaeuse/rebel9_aluminum/index_en.html?id=r9alu
  14. stevenrlp
    stevenrlp What's a Dremel?
    23 May 2010
  15. escafoxx
    19 May 2010
    All parts ordered
    Opted for the Sharkoon one
    Thanks for all taking time out to suggest what you did to me
  16. Fingers66
    30 Apr 2010
    Cool, come back and tell us how you get on.
    I, for one, particularly want to hear about the Sharkoon case. It is very, very good value for an aluminium case so I would like to hear your thoughts on it if you wouldn't mind.
  17. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    +1 - Mini review, plz?
  18. stonedsurd
    11 Mar 2009
    That Sharkoon case looks hawt. Does anyone know whether they're available in the USA?
  19. PureSilver
    16 Dec 2008
    ...Ah. Further investigation suggests this isn't an all aluminium case. What I think you get instead is an aluminium front panel mounted on the steel backbone of the standard Rebel chassis. It looked too good to be true, and it is. Still looks pretty damned good, though.
  20. stonedsurd
    11 Mar 2009
    :waah:
