Build Advice New Build! Compatibility/Advice?
Discussion in 'Hardware' started by hash3m, 8 Sep 2009.
  1. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    To be honest i think you would be a fool to buy that.
    You know you can do SLI on the p55 I5 motherboards yeh?
    Why would you need to drop the 260 SLI?
    I'm not sure buying those is a great idea anyweay so close to the launch of a new series of GPU's..(this week?)
    i5 750-$209.99 (Q9550 $219.99)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
    GIGABYTE GA-P55-UD4P Support 2 Way SLI & CrossFireX $169.99 (XFX MBN790IUL9 $174.99)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128400
    So basicly you are saying you want to pay MORE money so you can have a slower computer with no upgrade potential...
  2. hash3m
    hash3m What's a Dremel?
    8 Sep 2009
    Mad respect. You might have just changed my mind. I've been under the impression that you cannot SLI on the p55 boards. I never saw SLI anywhere.
    Then I might be able to afford 4x 2gb dual channel.
    I want to be absolutely positive you can SLI a p55 board.
  3. Slizza
    23 Apr 2009
    Yes you can SLI on a p55 board and a x58 board.
    100% no doubt about it whatsoever.
  4. hash3m
    8 Sep 2009
    1 final question before I sell you my soul.
    Will that board support this RAM?
  5. Slizza
    23 Apr 2009
    You will need to run lower voltage ram.
  6. hash3m
    8 Sep 2009
    Anything specific? I don't understand those numbers yet...
  7. Slizza
    23 Apr 2009
  8. hash3m
    8 Sep 2009
    Am I dreaming? This keeps getting better!
    I want to look for OCZ/Corsair RAM. Should I? If so, what numbers do I look for to make sure it's compatible with the board?
    And finally, is this PSU compatible?
  9. Slizza
    23 Apr 2009
    You wont get any more out buying OCZ/Corsair ram.
    I would recommend a corsair PSU over that one you linked to, but it will do the the job yes.
  10. hash3m
    8 Sep 2009
    JACKPOT!
    I have to go to sleep I will marry you in the morning. Thank you!!
  11. Slizza
    23 Apr 2009
    You could just press the "add rep" button below my post count to say thanks :D
    Oh actualy i think perhaps 800w PSU would be a better idea for SLI 260's.
    Should work fine on 700w but more headroom is always a good idea.
    hash3m likes this.
  12. wyx087
    15 Aug 2007
    very good stuff from Slizza.
    most p55 supports SLi and Crossfire, look at the spec closely! the Gigabyte board posted does support SLi. for RAM, anything up to 1.65v is fine.
    if you REALLY want Corsair, here are their RAMs (go down the page), but their prices is a bit steep i personally would buy the G.skill.
  13. hash3m
    8 Sep 2009
    This is it guys. 4 days in the making. I present, the $1500 i7-optimized Build:
    MOBO: GIGABYTE GA-EX58-UD3R ATX - $450 combo with cpu
    CPU: i7 920 Nehalem - $450 combo with mobo
    GPU: 2x GTX260 - 2x $195
    PSU: Thermaltake W0116RU 750W SLI Ready - $110
    HDD: 2x WD Caviar Green 500GB 32MB - 2x $57
    RAM: (3x 2gb) OCZ Obsidian DDR3 Tri Channel - $120
    CPU COOLER: Scythe MUGEN-2 SCMG-2000 - $37
    CASE: COOLER MASTER HAF 932 - $140
    OS: Vista Home 64bit (Free Win7 upgrade) - $110
    Total: $1471 -$95 MIR
    Please help me get these last few questions squared away, and let me know if you find any problems with the build. THANK YOU ALL SO MUCH FOR ALL YOUR HELP!!! :D :D :D
    - Is the RAM compatible with the mobo?
    - Is the PSU compatible with the card and mobo?
    - Will the cooler fit the mobo and case?
    - Does it matter if the HDD doesn't say 7200rpm (doesn't list rpm at all).
  14. wyx087
    15 Aug 2007
    RAM: perfect
    PSU: Tt is not a crappy OEM make, so could be fine
    cooler: should be fine, since HAF is designed with that in mind. but need someone else with the case to confirm
    HDD: doesn't matter. but for installing OS, you really should get a WD Black, the access time is more important and Green drives are terrible at it
  15. hash3m
    8 Sep 2009
    I swapped the mobo, HDD, and PSU ;) Everything should be in line now...
    MOBO: MSI X58 Pro-E LGA 1366 X58 ATX - $190
    CPU: i7 920 Nehalem - $280
    PSU: CORSAIR CMPSU-850TX 850W SLI Ready - $140
    HDD: 2x WD Caviar Blue 500GB 7200rpm 16mb - 2x $57
    Total: $1521 -$80 MIR
    - The PSU is quality and powerful enough, but do you think it will be compatible with the cards and mobo?
    - Will 16mb cache be fine on HDD?
  16. trig
    trig god's little mistake
    10 Aug 2006
    why pay $5 more for that when g-skill is just as good?
    that looks familiar lol...
    1:um, why pay more for ocz/corsair?
    2:thermaltake's are not the way to go. corsair, seasonic, tagan...
    typically tough power series is ok, but spend the money to get a silver certified seasonic, it has 76 amps over dual rails>72 amps over 4 and this particular thermaltake is actually a rebadged cwt.
    lol...what? no love for trig? HE STOLE MY SUGGESTION...lol
    the board you chose does not support sli...for pete's sake man...why can't you take the advice?
  17. Von Lazuli
    Von Lazuli I get by fine with a jig-saw.
    23 Oct 2008
    That looks like a great build. I must admit, I was a little skeptical of SLI'd 260s on the P55. It doesn't exactly have a lot of PCI bandwidth to throw around.
    Only thing I might mention is RAM, Photoshop likes a lot of RAM, and although 12GB might limit your overclocking potential, it may be worth looking at in the future if you need more speed. Oh, a little thing I would change from your build, if you can stretch to the Caviar Blue 640GBs they would likely be a little faster due to a higher data density.
    Laz
  18. hash3m
    8 Sep 2009
    Yeah but trig, check out this build I finished with!!:
    HDD: 2x SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM 16MB - 2x $50
    Total: $1507 -$80 MIR
    von, I would love to go with the 650gb but I'm over budget, I already had to drop the WDs for Samsung to cut $14... But the tx850 gives me enough power to upgrade the RAM later, and I probably will.
  19. trig
    10 Aug 2006
    last post for me...seems like you're not all there in the head...
    a 1TB western digital caviar black is faster, has more cache, and is cheaper than 2 x wd caviar blue's...and i am pretty sure that mobo does not support sli either...
    edit:
    actually, it does. it's the x58 pro that doesn't...and yes, the psu will work, but it is not modular...and you don't need anywhere near 850 watts...
  20. hash3m
    8 Sep 2009
    Relax man. Thanks for your help and stuff. If it looks hectic that's because I'm on 5 forums including here, constantly getting new info on what to improve. And then I update the build so everyone is aware of the changes, then it starts over again. I've been at this computer desk for like 4 days straight.
    I use 2x HDD because photoshop uses a scratch disk.
    850w because I'll be overclocking the cpu, the RAM, and probably GPUs eventually. I will likely up the RAM eventually, and overclock that too. If you think the tx750 can pull it, well then advice is what I'm here for. Sorry if you're out.
