Build Advice New Build - Gaming Pc
Discussion in 'Hardware' started by auctus, 8 Jul 2011.
  1. auctus
    auctus What's a Dremel?
    8 Jul 2011
    Hi all,
    I am after some advice on what you think i should get for my new computer, my information is as follows:
    Budget: $1000- $1400 Australian dollars (Approx the same as US)
    Main uses of intended build: Gaming and general use
    Parts required: All
    Previous build information (list details of parts): None as i am giving my current PC to my mother.
    Monitor resolution:
    Storage requirements: 2TB most likely, wouldn't mind an SSD as well
    Will you be overclocking: yes
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): May upgrade to SLI in the future if that is applicable otherwise no specific requirements.
    Extra information about desired system: I have looked into the various components and was aiming for an i5 or i7, 8 gig of Memory and possibly a GPU like the MSI GTX 560 Hawk Ti.
    Any help you can give would be very much appreciated.
    Regards, Auctus
  2. trig
    trig god's little mistake
    10 Aug 2006
    what games do you plan on playing and at what rez?
  3. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    A few threads in this forum for recommendations on an £800 PC which I believe is in the ball park of $1000 - $1400 Australian Dollars.
  4. auctus
    8 Jul 2011
    Hi again, my resolution is 1600x900
    Furthermore i looked into the forums a bit more and came up with:
    CPU: Intel core i5 2500K
    Mobo: Asus P8P67 Pro B3
    Memory: G.Skill 1600 2x4 Gig
    Graphics: MSI Geforce GTX 560TI Hawk 1Gig
    PSU: OCZ ModXSteam Pro 600W Modular
    Case: Coolermaster HAF 912 Advanced
    Storage: Seagate Baracuda Green 2TB
    Optical: Generic Samsung DVDRW
    OS: Windows 7
    IS this a reasonable build for its ~$1300 (~880 GBP) pricetag? Also i have a few questions:
    1. What is a good alternative to the graphics card as supply in Australia for this card seams to be running dry atm.
    2. Is 600W enough for my system?
    3. Is the motherboard the best choice or is something from MSI such as teh MSI P67A-GD65 a better choice?
    Thanks for you help guys
