Other New build pc locking up
Discussion in 'Tech Support' started by Sgoaty, 11 Dec 2025.
  1. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    Really hoping you guys can help as I'm pulling my hair out here.
    I've just finished putting together a gaming system with the following specs.
    7800x3d
    Gigabyte B650-DS3H
    32gb crucial ddr5
    9070xt
    It all seems to work great until I reboot after the driver install then nothing will open or launch with the exception of file explorer.
    So far I've tried, 3 fresh windows installs, 2 different ssds, a different RAM kit. I then removed the WiFi card thats installed.
    I even resorted to changing out the motherboard them swapping the PSU as I'm using extensions on the original build. I even tried 2 different 7800x3ds and a 7600.
    The system performs perfectly with the 7600 installed which doesn't make any sense to me. The 7800x3ds came from Ali express but I've bought from them before and they were fine surely they can't both be knackered?
    Can anyone offer anything else to try?
    Thanks
    Scott
  2. Gareth Halfacree
    4 Dec 2007
    Have you gone back to the original listing and checked for recent reviews? Lot of stuff on Ali that's been rebadged or is reject pile recovery. There's a reason they're cheap!
  3. yuusou
    yuusou Multimodder
    5 Nov 2006
    So you've changed out everything except the GPU, and the system worked fine in all occasions where the CPU was the 7600? Not gonna lie, seems pretty clear where the issue lies.
    Have you updated the BIOS on both motherboards? Does it still happen if you don't enable EXPO?
    What if you set a static, low clock frequency?
  4. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    I'm currently installing one of the 7800s in place of my 7900 and I'll see what happens if that system stops playing ball then all it can be is the CPU.
    They don't seem like a bargain if it's cost me a whole day.
  5. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    Tried without expo but didn't make a difference
  6. yuusou
    yuusou Multimodder
    5 Nov 2006
    If you get that far, check what CPU-Z says about the CPU.
  7. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    Working perfectly on my Asus b650-e-f
  8. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    Well I've got no real idea what's been going on TBH I tried memory again one stick at a time, expo and not expo. Tried using both sticks the same way and it worked ok but not in expo
    I have upped the RAM voltage to 1.375v(from 1.35v) and now it seems ok.
    It's very strange as I did try a different memory kit earlier and it was still the same. Head is fried with it!
  9. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    Did 6 hours of prime 95 last night everything was great. Turned it off overnight and having the same issues today
  10. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    Only components which were common was the GPU and sn550 SSD both removed from systems without issues.
    Removed both, performing fine, reinstalled GPU performing fine.
    Not sure why the SSD would cause this? It's been a storage drive only in the last system and this system. Showing 100% health too. It's out now and so far so good....
    Nope back to playing up again WTF!
  11. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    Are the motherboard standoff screws in the right place on case? Is cpu cooler backplate touching anything it shouldn't on mobo?
  12. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    Yes no weirdness at the back or anything. As a final hail Mary today I installed older adrenaline drivers and disabled the igpu. So far so good but I've thought that before
