Build Advice New build suggestions - help appreciated :-)
Discussion in 'Hardware' started by Mk1Slider, 13 Feb 2011.
  1. Mk1Slider
    Mk1Slider What's a Dremel?
    30 Jul 2009
    Hi all,
    Im looking for advice on a build so I've come here!
    Budget:£800 max (including display, but possibly excluding postage)
    Main uses of intended build: Gaming, Photoshop (only amateur level though), general surfing etc.
    Parts required:Everything except a PSU and OS.
    Previous build information:No previous build
    Monitor resolution:No monitor yet!
    Storage requirements: No specifics
    Will you be overclocking: Big Yes!
    Any motherboard requirements: Nothing specific
    Extra information about desired system: I'm swaying towards an i5 2500k, and Im ok with buying now and swapping the mobo when the recall happens. Ideally id like a gtx 560 as my gpu to. But i'll take all suggestions!
    Thanks in advance :)
  2. Dae314
    Dae314 What's a Dremel?
    3 Sep 2010
    What kind of display are you thinking of? I posted this build in another thread, but it sorta fits here:
    You say you don't need an operating system or PSU so if we minus £135 from the total there there's more than enough space in that build to get an i5-2500K and accompanying motherboard and 560:
    i5-2500K (£162)
    MSI P67A-GD55 (£129) - doesn't have to be this
    GTX 560 (£200)
    price difference from parts there: +£173
    minus OS & PSU: -£135
    total w/ SB stuff in it and 560 minus OS & PSU: £773
    You're in budget with a bit to spare! You might be able to use the extra to get a somewhat better case or better motherboard or better monitor or you could be happy with being under budget ^^.
  3. Deders
    Deders Modder
    14 Nov 2010
    What is your current PSU?
  4. Mk1Slider
    30 Jul 2009
