New C2D PC, but random hangs and crashes!
Discussion in 'Tech Support' started by bahgger, 15 Oct 2007.
  1. bahgger
    bahgger Minimodder
    13 Apr 2005
    I bought new components recently and so my new PC setup is as below:
    Intel C2D E4400
    2GB RAM
    Asus P5K-SE Motherboard
    8800GTS 320MB
    400GB WD HDD
    200GB Seagate HDD
    Creative Audigy 2
    DVD-RW
    500W PSU
    I installed everything and installed Windows XP Pro with SP 2 and got everything else I use installed. The problem is that, while at the desktop, the PC hung with a continuous beep coming from the speakers. This isn't as bad as when I had a beep and hang when playing Airborne, which I fixed with the 1.1 update.
    I suspected a problem with the C2D so I got some Microsoft dual core patch, then I suspected a problem with the onboard sound, so I disabled it in the BIOS. The problem has just occured once, but I'm quite sure it will occur again because the PC doesn't seem stable at all - the PC will sometimes hang at the WinXP loading screen.
    I've updated Windows update and installed the latest drivers for everything. Any ideas?
    I have no problems in Portal, TF2 and EP2 so I think the problem may stem from MOH: Airborne, although the WinXP loading screen hang is confusing me too, and may suggest a problem in the bigger picture.
  2. Guest-16
    Guest-16 Guest
    What PSU?
    More core and memory voltage? Depending on temps and heatsink.
  3. bahgger
    bahgger Minimodder
    13 Apr 2005
    No overclocking done to any parts whatsoever at the moment, so stock E4400 2.0Ghz with stock heatsink.
    RAM is Corsair TwinX CL-4 PC6400 stuff (2 x 1 GB) if I'm not mistaken.
  4. Guest-16
    Guest-16 Guest
    What's your temps like and what PSU are you using?
    A touch more voltage through the memory (2.0 should do) and CPU might help.
  5. bahgger
    bahgger Minimodder
    13 Apr 2005
    Below 30 degrees C Idle and no idea about load. I'm using an Ultra X-Connect 500W (I know - I'm sorry.. I was tempted by the shinyness). Do I need to up the voltage even in a stock clocked system? That sounds peculiar.
  6. WTF_Shelley
    WTF_Shelley The picture is wheeljack
    6 Apr 2005
    Have you tried using Memtest86 boot floppy, weird game issues are mostly Temp or ram issues.
  7. bahgger
    bahgger Minimodder
    13 Apr 2005
    Okay, I'll try memtest, but is there a way to do it without a floppy disk? I haven't had one of those for the last 5 years!
  8. bahgger
    bahgger Minimodder
    13 Apr 2005
  9. kenco_uk
    28 Nov 2003
    Try Ultimate Boot CD - it includes memtest and a utility to make a ubcd usb stick.
  10. Guest-16
    Guest-16 Guest
    The Ultra X3's are great, I've not tried other models though.
    Up the voltage to see if the voltage drop (vDroop) is particularly abnormal in your board, or it may not be picking it up right. Stick your ram at 2.0 and CPU at 1.3-1.35 and see what happens.
  11. bahgger
    bahgger Minimodder
    13 Apr 2005
    I've done what you suggested, bindibadgi. I'll see how this goes, although I've recently had really stupid crashes in IE7 and once or twice in TF2 so I'm not sure if it's just the CPU n RAM! The XConnect I have is the first gen 2 x 80mm with thick modular cable one, not the X3s...
    Will try the Ultimate Boot CD when I find a CD-R!
  12. Crazyglue
    Crazyglue What's a Dremel?
    27 Nov 2005
    to be honest, if ur using the first get x-connects, with ur setup, it could probably be that, if u have the money, go get a 600w+ psu from ur local computer store, then if that doesnt resolve it return it :worried:
    also (im not entirely sure about this), but the mobo u have is 1333/1066mhz fsb, while ur cpu is 800mhz fsb. dunno if this will make a difference. Try updating ur bios, and make sure u have all up-to-date drivers.
    just some thoughts :hip:
