hello, I am currently in search of a new camera (for a xmas gift to someone)with a budget of around a £100 but could strech to about 150 if it is worth it (I.e a camera which can last longer/have more functions/Better quality etc) Yes i am a noob at all this camera stuff so i dont really know where to start to look for type of model etc Also if possible a decent photoprinter if possible (Not in the budget price) Thank You
You need to read through these threads: http://forums.bit-tech.net/showthread.php?t=143022 http://forums.bit-tech.net/showthread.php?t=143123 http://forums.bit-tech.net/showthread.php?t=143207 And then go through the various review sites (like www.dpreview.com) with your shortlist of cams to see if they match your expectations.
Thanks for reply How about the Panasonic Lumix Range http://www.ebuyer.com/product/134638 http://www.ebuyer.com/product/134889 http://www.ebuyer.com/product/126122 I know its a bit of my budget but if there worth it i might as well take them
Update I think we have a winner out of the LUMIX ranges-DMC-TZ3 So is there now anything better than that.. Also anyone have a decent photoprinter (hp ones look good) that they can recommend
I'm going to be a little controversial here, and agree with Ken Rockwell on something. Basically no consumer printer can match the printers they have in photo labs for quality; and the labs are cheaper than printing your own now anyway. So I would forget about the printer entirely, then you don't have to worry about paper, clogged nozzles, and all sorts of other hellish inkjet nasties. As for the cam - go into a shop and try it out At 7x5 (standard size for digital prints), you won't be able to tell the difference between most compacts. But you will be able to tell the difference in operation, and that matters a lot more than slight image quality differences that can't be seen.
