A/V New car head unit
Discussion in 'Hardware' started by Buzzons, 18 Jun 2013.
  1. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    All,
    Current car has a Kenwood head unit that, while serviceable, has an annoying "one button does everything" kind of interface.
    So what would everyone recommend .. it needs to be able to do the following
    USB in (preferably on the back)
    Aux In (pref on the back but front is fine too)
    Play MP3 CDs
    It would be nice if it could do BT Audio streaming from a phone ->> car speakers but that's a nice to have not a must.
  2. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
    Alpine is what I swear by. Functionality and styling and sound quality all top notch in my experience
    Sent from my Galaxy Nexus using Tapatalk 4 Beta
  3. Somer_Himpson
    22 Jan 2010
    My particular model has all the functions you mention. I use both rear USB which pi run a lead from to by my feet so I can unplug when adding or changing the contents and my phone now and then when I forget USB. It also can connect to internet radio if you have an iPhone. CDE 135BT is the model number. I would highly recommend it. It also has 3 pre-outs for connecting after market speakers amps etc. The only thing it doesn't have is DAB but you can get the next model up in the range if you need that as well. I have 4 Infinity speakers hooked up to an Alpine amp and subwoofer with its own built in amp. Amazing sound quality.
  4. Jeevus
    Jeevus Minimodder
    6 Sep 2009
    What is your budget? I just bought a head unit this week and my requirements were:
    iPod connectivity (rear)
    CD
    Bluetooth
    I was looking at the CDE-174BT here.
    I ended up buying this though as I preferred the styling.
  5. Buzzons
    Buzzons Minimodder
    21 Jul 2005
  6. Somer_Himpson
    22 Jan 2010
  7. Somer_Himpson
    22 Jan 2010
    Also, don't shop in Halfrauds obv
  8. Somer_Himpson
    22 Jan 2010
    £139 here:-
    http://www.carsoundsandsecurity.co.uk/store/cde-w235bt/
    And customer reviews on Crutchfield:-
    http://www.crutchfield.com/S-X4MLNG3uWQ9/p_500W235BT/Alpine-CDE-W235BT.html#customer-reviews-tab
  9. jizwizard
    jizwizard Modder
    24 Dec 2010
    Back in the day it was either alpine or pioneer, you couldn't go wrong with them.
  10. keir
    keir S p i t F i r e
    5 Oct 2003
    http://caraudiosecurity.com/kw-av50-6-1-inch-wvga-touch-panel-monitor-with-dvd-cd-usb-recei
    £180 - the one I'm getting when I get my money :)
  11. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    thanks for all the links chaps - one assumes that the alpine can do BT audio streaming?
    Other than the double din units - anyone got any recommendations for a single din one?
    also - are there any nice alpine ones with both a read and a front USB port? rear would be good as it means i can put something in the glove box like an ipod and forget about it.
  12. Somer_Himpson
    22 Jan 2010
    I have listed my unit which comes with front and rear usbs and it streams audio via BT
  13. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    aye - it looks good for a single din unit - any idea if there's a similar one that's double din?
  14. jinq-sea
    15 Oct 2012
    I recall that Alpine does a double DIN equivalent - lemme have a look :)
  15. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    looks like the only two current double dinn head units from apline are no where near as good as some of their single din units!!
