Motors New Car Time
Discussion in 'General' started by dirtbiker, 2 Sep 2005.
  1. dirtbiker
    dirtbiker What's a Dremel?
    24 Dec 2003
    I'm off to uni in September and i'll be taking a car with me. Question is; What Car? :p
    Its going to be used for motorway driving every weekend so it'll have to be able to maintain an easy 70mph without drinking too much petrol. It also needs to be cheap to insure (comparable to my 998 mini would be nice) and reliable.
    Any ideas?
    Chris
  2. Headspark
    Headspark Minimodder
    23 Feb 2005
    fiat puntos go easy on the fuel i believe!
  3. alextwo
    alextwo <a href="http://forums.bit-tech.net/showpost.php?p
    29 May 2003
    An mpi mini :p
    Mine is comfortable enough and is pretty decent for motorway cruising.
  4. dirtbiker
    24 Dec 2003
    Interesting, hadn't thought of that at all... :D
    I might be looking for a Suzuki Swift any thoughts on that particular automobile?
  5. pranks7er
    pranks7er mange tout
    25 Dec 2002
    wat about pug 106
  6. SHAKIRALOVER
    SHAKIRALOVER What's a Dremel?
    24 Feb 2005
    I wouldnt buy Peugeot, Fiat or Suzuki. Id have the Mini, or a Micra, cos there pretty much bulletproof.
  7. samuelellis
    samuelellis What's a Dremel?
    19 Apr 2002
    pug 306 td/tdi/hdi
    i had a 306 d (non turbo) and i abused it and it kept coming back, my mum has had a 306 d for aaages and never had many proelbmes with it
    they are group 4/5 insurance iirc
  8. slater
    slater Mummy Says Im Special
    18 Apr 2003
    I was going to mention Suzuki Swifts or early pug 106s with the factory body kit, Both slammed on steels ofcourse :)
  9. hitman012
    hitman012 Minimodder
    6 May 2005
    Late 90's Nissan Micra is always a good choice, cheap to run and built well.
  10. D4VID
    D4VID What's a Dremel?
    17 Nov 2004
    Fiesta 1.25 Zetec (if the budget can stretch to ~£2k)
    My sister has one and its a great little car. 40+ mpg and cheap to insure. Surprisingly powerful for a small engine, very revvy nature (down to the design collaboration with Yamaha). Close to the 1.6 zetec performance wise but a whole lot cheaper.
    Very refined for a small car, and will cruise easily at 70 (or 90 :)).
    I would generally advise against most french/italian cars because of reliability issues, especially Fiats. The Pug 106 is very nippy for a 1.1 due to its lightness and handles well but it won't be as comfortable on a motorway as the Fiesta. Also has annoyingly offset pedals and would crush like tin foil in a crash.
  11. olv
    olv he's so bright
    23 Sep 2002
    a budget might be useful :)
  12. Murdoc
    Murdoc Gas Mask..ZOMG
    25 Jul 2003
    My MK.1 pug 106 1L only takes sniffs of petrol and does 90mph on the m/way when pushed, its getting a reconditioned box on weds. Its great to drive and pretty much the cheapest insurance you can get.
    I pay £1250 for insurance where a 306 td 1.9 is £2200 :/
    'doc
  13. Spiral Architect
    Spiral Architect Cooked on Phonics
    4 Sep 2003
    I got a mk 3 Astra 1.4i which is fairly cheap to insure. Especially when you give them loads of hassle on the phone.
  14. Krikkit
    21 Jan 2003
    As far as Fiat Punto's go the mk1's are pretty decent. Mine gets ~45 to a gallon on the m/way (at 80-90mph), it gets up to about 50 if you slow down a bit.
    One thing i will say though, make sure you find one with uprated trim, the trim in mine is excellent, and far FAR more comfortable for doing motorway miles than the normal one. :)
  15. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    get a micra, don't listen to anyone who says they're slow and boring. they're cheap to insure, handle very well and they're nippy.
  16. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    mk2/3 golf
  17. fantastic dan
    fantastic dan Minimodder
    26 Jan 2004
    i've got a 306 that i quite like, its very comfortable. Suzuki swifts are nice and also very comfortable. However the two that i have known off both had expensive issues after a few years.
    The punto first model that my friend had was a total piece of crap as was the fiat that my dad had many years ago. Althought he same can't be said for every one. I personally wouldn't go near one.
    I'd just see if you could take the mini.
  18. webbyman
    webbyman Hax.
    7 Oct 2004
    arn't micra a little ugly and the engines need some serious revvin to get them moving a few mph
  19. -:: M@ ::-
    -:: M@ ::- Testify!
    3 Oct 2003
    Micra definatly, ive had mine and taken it to Notts, Liverpool, Leeds, Devon, London and Newquay motorways, and cruise at about 90 with no rattles, its fine for motorway driving and does about 12 miles to the pound on the motorway which aint bad for a little car, make sure you get a 1.3 micra though as the 1 litres will have problems on the motorway...
    and webbyman, the new micras are ugly, the 90-01 version are nice looking though, like 1/2 mini 1/2 206ish, and damn well fast, can top 120 with the 1.3 models
    - M@
