Planning New concept (OSIDIAS), The CNC arrives!
Discussion in 'Modding' started by craigbru, 6 Feb 2009.
  1. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    oh :) good luck. i guess setting up a cnc will take quite some time though
  2. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Yeah, it's going to come in handy. :D
    Well, it shouldn't be bad. It's mostly software issues I have to take care of. I'll have my Hive Logix system running tomorrow, and I can start installing everything. I've also got to wait for my end mills to arrive. It may be a week before I get to cut anything. :sigh:
  3. Cheapskate
    13 May 2007
    Belts?:eyebrow: I guess that's one way to keep the cost down. On the plus side, you shouldn't need to oil the crap out of this setup.
    You might need some toothbrushes mounted on the Y gantry just in front of the rollers. I can see chips getting in there already.
  4. craigbru
    28 Feb 2008
    Yeah, it's belt driven. Although I've not heard of any complaints regarding them in this particular machine. One thing is for sure... This thing is solid. Solid beyond belief. I'll take some better pics of it's construction when I get a chance. I've got no doubt this machine could take substantial abuse. Kudos to Romaxx for overbuilding it in almost every way.
    Toothbrushes, eh? That's not a bad idea at all.
  5. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    that is a solid piece of kit you got there! Worth while investment!
  6. craigbru
    28 Feb 2008
    Indeed! I'm hoping to get quite a few years of use out of it.
  7. murtoz
    murtoz Busy procrastinating
    9 Apr 2008
    Fixed that for you.
  8. GuyInTulsa
    GuyInTulsa Dremel Molester
    6 Jun 2009
    CNC !
    CNC !
    CNC !
    CNC !
    The natives are restless....
  9. craigbru
    28 Feb 2008
    :D
    Well, I'm still waiting for mill bits to arrive. Although, over the weekend, I did get the machine hooked up and ready to run. I've got the Hive Logix PC (Atomic H2O) finished, and a copy of Mach3 installed. Everything should be tweaked and ready for g-code. I was able to jog the machine around in the software, so hopefully I should be good to go.
    I've also got an inexpensive airbrush on the way for my aluminum cutting mister experiment. :thumb:
    So, maybe this next weekend!
  10. Dark~3nergy
    14 Jan 2007
    yay :D can't wait to see it in action !
    i need one too :worried:
  11. Elledan
    Elledan What's a Dremel?
    4 Feb 2009
    The only thing better than CNC may be a rapid prototyping machine :D
  12. Dark~3nergy
    14 Jan 2007
    for 5x the cost yes, but i doubt you could make parts that are solid enough though.
  13. Elledan
    4 Feb 2009
    Depends on the type of RP machine used. Some produce parts which are just as durable as the production parts. Saves having to make molds and everything which can get even more expensive :)
  14. Evenge
    Evenge Minimodder
    16 Sep 2006
    Can't wait to see what magic this CNC will produce! :D
  15. GuyInTulsa
    6 Jun 2009
    C N C !!!
    C N C !!!
    C N C !!!
    Can't wait...
  16. craigbru
    28 Feb 2008
    You do need one! :D
    Oh yeah, don't even get me started on how much I would want one of those. I'm pretty sure I can't get one of those sponsored...
    Thanks guys. I'm hoping to cut something this weekend!
  17. Elledan
    4 Feb 2009
    A while ago I nearly ended up making the embedded hardware and software part of a RP machine for a Canadian company which was looking at making its own RP machines. Did a lot of research into how these little beasts work, software and hardware-wise. My two thoughts are that projects like RepRap are cute, but will never be useful for anything, and that it should most definitely be possible to build a reasonably accurate RP machine for less than 5,000 Euro, depending on which method you need. Most of the costs goes into getting accurate guidance (which is why belt-driven is only an option for CNCs, not for RP) and the software which generates the description models.
    Maybe when I'll ever have time I should do some more research and put a little guide on this together :p
    Just make sure you cut the right parts :D
  18. nlancaster
    nlancaster Minimodder
    21 Dec 2009
    and don't forget to make left and right parts.
  19. craigbru
    28 Feb 2008
    RP machines are definitely interesting, but I'll admit to not knowing much about them.
    If I manage to get anything cut, it will be something lame, and likely out of wood. I need a little practice before I commit to anything valuable. :D
    Haha, I'm lucky enough to not have many parts shared between sides. Actually, I think the cage might be the only thing with duplicated parts.
  20. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    You could just stick a pen in it and let us watch it go! :D We have a fairly large 8' X 12' I think, cnc table at work. I don't get to play with it though. :waah: I've got a video of it on my site.
