Planning New concept (OSIDIAS), The CNC arrives!
Discussion in 'Modding' started by craigbru, 6 Feb 2009.
  1. null_x86
    null_x86 Thread Closer
    18 Jan 2009
    eep, measuring is mm = :wallbash::wallbash::wallbash: alrighty, then, ill have to take a look at rouge, but sounds good! 5/5 so far :rock:
  2. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    I managed to get the interior tray about 90% finished over the weekend. Here is a pic of what I've got so far. Most of it will be bent out of a single piece, and the rest will be brazed together.
  3. HaoKi
    HaoKi Lleno de anguilas!
    10 Oct 2003
    Now this is starting to look even more interesting :)
  4. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    Wow, bending all that from a single piece... arent you afraid you'll mess up one little corner and have to do the whole thing again? I hope i didn't just jinx it btw. :eeek:
    I like how ultimately functional this part looks by the way. It just oozes purpose. :clap:
  5. craigbru
    28 Feb 2008
    Thanks man!
    Yeah, messing up is a fear of mine. If I do screw it up, it will be in the layout, and not the bending. An aluminum sheet large enough to make the tray is going to be pretty pricey. I'll measure a dozen times, and cut once... :thumb: Nothing ventured, nothing gained, it will be pretty awesome to say that it's a single piece.
    You are right about the piece's functionality. It's only what is needed, and every part of it has a purpose. :D
  6. craigbru
    28 Feb 2008
    Another updated pic...
  7. yeknom
    yeknom What's a Dremel?
    23 Apr 2008
    what thickness metal will this be made from?
  8. HaoKi
    10 Oct 2003
    This project is coming along nicely. :) You really have the outer shell figured out and it looks really interesting. The biggest problem with my own design have been the sides, they end up boring because I can't figure out what I want to put on them :D
  9. craigbru
    28 Feb 2008
    It will be 2mm aluminum for the case, and 6mm aluminum for the cage and handle.
    Thank you! Yeah, I've been tweaking the side panels quite a bit. It's evolved from something more sleek, to something more industrial, but I like it. I'll give you credit for inspiring me with the panel lettering cutout. It looks great on your Eutanasia project, and I thought it would look great here as well. :thumb:
  10. craigbru
    28 Feb 2008
    Okay guys, I've been playing around with renders. Since I'm using ViaCAD, Kerkythea isn't as easy to use as with Sketchup. I've basically got to export a .dxf, and then import it into SketchUp. However, when I do, not everything gets exported. I'm not sure how to fix that yet, but I'll keep playing around with it. So, the render below is missing a few components...
  11. renba
    renba hooch is crazy
    2 Oct 2008
    looks really nice :D
    Hope you'll start soon
  12. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    mmmmmmmmmmmm complex! hahaha
  13. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Looking awesome Craig going to be an epic project log!
  14. craigbru
    28 Feb 2008
    Thanks! I'm hoping to start in a month or so.
    Yeah, I did go little crazy on the details, but that's all part of the fun!
    Thanks man. I can't wait to get started. Despite all the labor involved, I've convinced myself that it won't take as long as the Rogue... :rock:
  15. craigbru
    28 Feb 2008
    Okay, I've got a small update here. I've added the LCD to the front, and an Aquaero to the right side. There's also a new reservoir on the rear, but I've got to finish a little tube routing before you see that.
    I probably should have added a few comments. The LCD is capable of rotation and swiveling. Left, right, up down, and portrait/landscape.
    One more thing... I've started to order a few parts... :D
  16. craigbru
    28 Feb 2008
    One more small update here. I've finished the interior tubing layout. Simple and efficient...
  17. tominated
    tominated What's a Dremel?
    28 May 2008
    wow that's cool. looks like it's gonna be an insane project!
  18. shomann
    shomann Minimodder
    5 Sep 2003
    Love it! I can't wait to see the crazy bending that will have to be done - I don't envy you. One question, you have right-angle fittings going into the waterblock - how badly will that hinder flow? I ask from the position of a complete water-noobie (and because I avoided placing the PSU over my CPU in my design for this very reason).
    Looking forward to watching this project. Good luck!
  19. craigbru
    28 Feb 2008
    Haha, thanks man!
    Thank you! Any right angle fittings at all will inhibit flow. However, it's a pretty simply loop, and the addition of the 90's shouldn't be that bad. A DDC should provide plenty of flow.
  20. HaoKi
    10 Oct 2003
    My old loop had two 90-degree turns more and the loop kept the cpu cool anyways so I think it's not going to be a problem for you.
