Cooling new cooling for a CM stacker
Discussion in 'Hardware' started by dead_man, 23 Aug 2004.
  1. dead_man
    dead_man Confucious say: WTF???
    4 May 2004
    im intending on getting a CM stacker and i want some uber cooling for it, so that means watercooloing, i probly will run dual PSU in the feckin thing and id like if u can recommed parts from this joint as im in Oz
    www.below-0.net
    here r my system specs.
    GB 7n400 pro2 (may change this but i like what i can overclock the thing so im not sure) also no bolt holes so keep that in mind
    AMD 2800+
    512 ddr333 and 512 ddr266
    mx440 soon to b 9600XT ultra
    2x optical drives and 5x Hdd
    who needs a floppy?
    i would prefer stuff this store has but nethin else will come in handy and they can alwayz order in for me
    ne help is much helpful thanx
  2. dom_
    dom_ --->
    4 Jan 2004
    good case choice ;)
    brilliant for water cooling, uddles of room inside
    if you need any info on case im happy to oblige
  3. dead_man
    4 May 2004
    yea i know, mate has one wif dual psu and a x800 things stays cold as a mofo
    59 posts and no1 has ne ideas? might get better help over in hardware and overclocking
  4. jetsetjimbo
    jetsetjimbo Up-up and away
    19 Feb 2003
    dom,
    How easy it it to mount 120mm fans in the front of it without buying additional 3 drive cradles?
  5. dom_
    dom_ --->
    4 Jan 2004
    ermm hmm... you would have to make some sort of bracket up really. they cant be screwed into anything you see... i will take pic...
    bit big but it shows the detail :)
    as you can hopefully see you would have to make a bracket that was held the fan and had sides bent inwards to attach to the sides. to attach it you could screw it in direct or use their holders that you screw onto cd drives and they then clip in place. you can see these in the pic, the black plastic piece down the side of the hdd holder.
    edit:
    also to the starter of the thread dead_man ;) we havnt forgotten you. i cant really comment on the gear your need cooling as i have only ever had pentiums and i have a different graphics card, i can recommend a decent radiator and res though :)
    as radiators go thermochill 120x2 seems good and mine is on the way to me now. also as for res's im get a tank o matic, purely for asethetics alone. because it will look so damm spanky in my case. as for positioning of the res see the grill at the bottom of that pic? it will fit there if i remove the grill and as the case is on wheels the fans will blow air over the rad and straight out the case. to keep airflow good i will reverse the rear fan in the case so i have 2x120mm's bringing air in, 2x120mm's blowing air out, and the top 80mm fan is going as a window will be replacing it in due time :)
  6. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    ooo cool dom:D Nice cooling, it quite?
  7. dom_
    dom_ --->
    4 Jan 2004
    yeah the 120mm's are only a little louder than my old 80mm's undervolted to 5v and these fans are running the full 12v :D
    im surprised how quite it is really :) and my temps went down so much changing from a coolermaster centurion. cpu temp went down around 8 degrees and case temp went down between 9 and 10 and hh'd went down about 10 too :)
    so instead of 40 degree hdd's i now have 31-30 degree hdd's :)
    although the metal behind the fan over the hdd's is going soon as i can feel rather a lot of air blowing back off this. so once this has gone hopefully hdd might go down another degree :clap:
    edit: removed these pieces and now hdd are at 28degrees :jawdrop:
  8. dead_man
    4 May 2004
    back on topic, does ne1 know what kind of watercooling setup i should use in this? coz this is the reason i wanted the case, for watercooling
  9. jetsetjimbo
    19 Feb 2003
    Something with a twin or triple 120mm rad i'd say. I was looking at this case for the same reason but unfortunately there dosen't seem to be a quick and easy way to attach fans to the front of the case... That's where I'd have the rad... there's that much room in there you could use whatever you like, just depends on budget.
  10. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    To be honest, with that much space you may as well just stand the rad up on the floor of the case, and cable-tie (or some other ghetto method of holding it in place) it to the drive mounting holes. You want the fans sucking air through the rad into the case anyway, rather than blowing through, so there's not much point in trying to mount the 120mm fans to the front. And the drive cradle things probably don't space the fans the right distance for a 120.2/3 rad, you'd have to do it yourself whatever you decide.
    Another thought is that you might want to cut blowholes in the top of the case and mount the rad there, though then you're sucking already warmed air through the rad...
