Case Mod - In Progress New DarthBeavis rig: Brimstone
Discussion in 'Project Logs' started by DarthBeavis, 29 Jan 2010.
  1. StEm
    StEm What's a Dremel?
    30 Nov 2009
    Not picking at your beautiful creation here, but with it being a high performance machine wouldnt the front panels small cut out shapes for the fans reduce possible airflow?
    ahhh who cares it looks sooo good it doesnt matter. lol
    big thumbs up..
  2. DarthBeavis
    DarthBeavis What's a Dremel?
    29 Aug 2008
    Definately a trade off but you need to realize I am using Feser TFC rads which are low density fin count high flow radiators that allow for low-speed fans. With the amount of surface area I have (two 480s) the reduced air-flow makes up for it. I am changing the pump setup to a dual D5 setup after QuakeCon.
  3. DarthBeavis
    29 Aug 2008
    Decided to update a bit. Changed out for Danger Den mobo block, took out skull as it caused too much restriction and added dual D5s instead:
    Here it is running a Starcraft II Tourney at BlizzCon in the ASUS booth:
    And running my 3d Surround setup at PDXLAN 16.5
