Modding New Dremel, and it looks GREAT!
Discussion in 'Modding' started by Stuey, 20 Oct 2009.
  1. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    Okay, so Dremel released a new rotary tool, the "4000". I've got to say, it looks great, and I want one, like NOW.
    It looks MUCH more ergonomic than the 400 XPR that it is replacing. Now... if only my 400 XPR is "accidentally" destroyed beyond recognition...
    (Full Story via ToolGuyd)
  2. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    there really isn't a huge difference between that and the 400 XPR
    but since it's almost the same price I'd buy the 4000
  3. Cheapskate
    13 May 2007
    The vents are still covered by your hand. I'd rather have one I could bolt to a jig.
  4. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Compaired to my 395 it looks good and there are some nice new addons for it.
  5. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    I have one. The tool can be held so that the rear vents don't get covered, but the front vents aren't so happy. After a while of heavy use the tool heats up and starts to rattle.
    I already opened it once. The motor and electronics look nice, but the control switches are quite flimsy. The speed control wheel flexes quite a bit when pressed. I'm afraid that it will break after some use.
  6. stonedsurd
    11 Mar 2009
    Is there any Dremel where the front vents are not covered while in use?
    I have a multipro cordless and two knockoffs and all of them get unbearably hot after about a half hour's work.
  7. Javerh
    5 Sep 2006
    Perhaps we should start modding dremels to make the cooling work better.
  8. stonedsurd
    11 Mar 2009
    That would pretty much be in tune with the spirit here! :lol:
  9. AJB2K3
    12 Dec 2005
    Who's going to try to water cool the motor? :jawdrop::jawdrop:
  10. The_Beast
    21 Apr 2007
    water + electricity = death
    but a nice and cool dremel
  11. dave_c
    dave_c Minimodder
    31 Jul 2009
    wh not just get the extending attachment (usually used for engraving i think) then you aint blocking anything.
  12. Unicorn
    25 Jul 2006
    I might be tempted into one of these, though I've been trying to get my hands on a Craftsman rotary tool for a while. Bill Owen's subliminal messaging in his videos is starting to work ;)
  13. Stuey
    20 Jan 2005
    There are [most] times when the flex-shaft is called for, other times when it just gets in the way and slows you down.
    As far as I can tell, the Craftsman version is a Dremel rebadge. I have a Craftsman router that's a Bosch rebadge, and since Bosch owns Dreme, I assume there's some sort of a Bosch-Craftsman cooperation that spawns these tools.
  14. Cheapskate
    13 May 2007
    A Rotozip vents out over the collet. Now if they just came with an adjustable collet... and a bolt down feature.
    I killed an older model Craftsman dremel too. It was poorly designed, and had a chunk of vinyl connecting the motor to the shaft.:eyebrow: Stuey is right, a lot of Craftsman tools are rebranded.
  15. Stuey
    20 Jan 2005
    An adjustable collet wouldn't be as secure as a fixed collet. As it is, it's fairly easy to pop different collets in and out.
    As for securing the Dremel, their vise does a decent job of it.
  16. AJB2K3
    12 Dec 2005
  17. Stuey
    20 Jan 2005
  18. AJB2K3
    12 Dec 2005
    Never failed to seculary hold any of my dremel bits of the cheep knockoffs.
  19. Stuey
    20 Jan 2005
    You can also slap a mill bit into a drill press chuck, but that doesn't meant that it's a good idea.
