News New dual-GPU ATI Radeon 5970 spotted
Discussion in 'Article Discussion' started by Sifter3000, 2 Nov 2009.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. AngusW
    AngusW mmm
    20 Oct 2009
    Wow that things a BEAST. Its massive.
  3. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    Sadly I don't have a house big enough to keep a video card of that size in! What's that? 13"? Maybe 14"?
  4. Sifter3000
    11 Jul 2006
  5. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    OK, I scanned the article rather than reading it properly...
  6. Singularity
    Singularity ******* Operator from Hell
    2 Mar 2008
    It really looks like an amazing card. Even if I'll never get to own it, it's still something awe-inspiring :D
  7. Hugo
    Hugo Ex-TrustedReviews Staff
    25 Dec 2006
    Clive clearly isn't a real journalist either, as demonstrated by his broken italics tag and the placement of an inverted comma inside a full stop. :D
  8. frontline
    frontline Punish Your Machine
    24 Jun 2007
    There's clearly enough room for a 3rd GPU in there :)
    Saying that, after trying crossfire on 2900, 3800 and 4800 series cards, i will probably stick with my single 5870. It is more than adequate for my native resolution and the games out there at the minute.
  9. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    what with the secret 'sleeve', I guess it is physics/cuda support which is faster then Nvidia. That would probably cause a big laughter all over.
    Hey, I can dream can't i?
  10. yuusou
    yuusou Multimodder
    5 Nov 2006
    What a beast. Hopefully someone was able to grab the performance numbers.
  11. mjm25
    mjm25 What's a Dremel?
    19 Jan 2009
    yum. big fan of the 4870x2 (as i bought one) this is more likely to be my next upgrade now that i've got a proper job.
    looked at the length and thought it was pretty similar to the 4870x2 (which is HENCH) but just realised that 10.5 inches is the length of that! so in other words FECK! that thing is long. have to be a full tower case or a bit of a dremel expert to fit that in. hopefully itll shrink a bit when they get the final cards out.
  12. mrb_no1
    mrb_no1 Pie Eater
    15 Sep 2007
    i dont need one... but i want one
  13. Panos
    Panos Minimodder
    18 Oct 2006
    I DO want one by the end of the year...........
  14. Jasio
    Jasio Made in Canada
    27 Jun 2008
    13.5" according to info that's available online. It will only fit in certain cases because of this restriction.
  15. TWeaK
    TWeaK Guest
    This definitely isn't the finished article. According to ATi's plan for the 5 series (can't remember where I saw it, probably somewhere on here) they're all going to have the same 'Batmobile' cooler only they'll have different sizes of cooler for the different PCB lengths. I wouldn't be concerned with the performance figures either - they're not going to be indicative of the retail product. Unless of course the performance was through the roof, in which case, it can only get better.
  16. cgthomas
    cgthomas Cpt. Handsome
    20 Oct 2009
    At first glance I though "That's a very thin gpu!!" then I noticed the massive size makes it look quite thin in comparison to its length
  17. dec
    dec [blank space]
    10 Jan 2009
    i wonder if these will have sideport and if it will be enabled, unlike the 4870x2's
  18. roblikesbeer
    roblikesbeer Bindi's sex slave.
    23 Apr 2009
    Long card is long.
  19. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Its not really, its just a piece of steel girder with some plastic stuck to it.
    How does it not snap the motherboard in half!!!!
    And it seems that they picked the smallest case possible to put it in, that makes it look even bigger.
  20. greigaitken
    greigaitken Minimodder
    26 Aug 2009
    Many people are fine with £450on a dual card but cry they gotta spend £100 on a big case to house it. It'sbetter buying a big case, so ati/nvidia get more space to play with. I like the idea of a separate graphics box that plugs into a pci express slot. This would make cooling those gpus so much easier. nvida made one before for multiplesli cards,but that was for pro rendering etc. Wouldn't it be nice to have a consumer version
Tags: Add Tags
