News New dual-GPU ATI Radeon 5970 spotted
Discussion in 'Article Discussion' started by Sifter3000, 2 Nov 2009.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
    :D
  2. Claave
    29 Nov 2008
    Well, there's already a HD 5000 card without a batmobile cooler:
    http://www.amd.com/uk/products/desk...d-5750/Pages/ati-radeon-hd-5750-overview.aspx
  3. nicae
    nicae New Member
    25 Nov 2008
    And a 5999 :D
  4. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    12.5 inches long and barely fits in an Antec Twelve Hundred, they will have to bundle a tub of Vaseline with it!
    A Crossfire setup with 2 of those beasts, is going to cause some airflow headaches.
    I personally think ATI has been a tad weak in naming the card, given its length, they should have named it the 'Trojan Magnum XL'
  5. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    this card is an sample card not the final product so it be longer then it should be, it most likely be an 11.5" card when it comes to retail as no card has been bigger then that before
  6. bogie170
    bogie170 New Member
    11 Aug 2008
    How much longer is it from a 4870x2?
    I'm not sure whether it will fit in my Antec P182 without having to remove the hard drive cage.
  7. wyx087
    15 Aug 2007
    +1 to that.
    what's the point of having zillian frame rates per second with 2 FPS being the minimal due to incompatible new game engine, when you can only see 60? isn't it better to have 60FPS with a steady minimal of above 30?
  8. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    The advantage to having a framerate far above 30 (or 60, in any case) is that it gives you some breathing room. I mean, if a card is consistantly capable of delivering 60 in all games, it'll choke during REALLY intensive moments. Damn smoke grenades!
  9. thehippoz
    thehippoz New Member
    19 Dec 2008
    cool- huang trying to squeeze one out and ati is all not this time sulu!
    what if those lucid boards actually work though.. 2 low end cards that don't have to deal with sli/crossfire driver code, and beat nvidia and ati's money maker sounds like a better deal to me
    hope it pans out anyway.. still waiting on the review when the boards are out
  10. uz1_l0v3r
    uz1_l0v3r New Member
    22 Sep 2009
    Indeed. In my view, any dual-gpu solution is pretty much overkill in today's pc game market. Unless you play Crysis/Crysis Warhead ALL the time.
  11. PandaMonster
    PandaMonster New Member
    18 Aug 2009
    Companies that are in direct competition with only one other company are singular? ROFL. *no fuc**** comment*
    Do some homework.
  12. TAG
    TAG New Member
    7 Aug 2002
    We very nearly had a similar length card aaaaages ago; the voodoo5 6000 which unfortunately was never to find home in our desktops.
    Here it is alongside a 9800GX2 and a 3870X2
    http://www.dvhardware.net/article26081.html
    EDIT: on second thought maybe it wasn't quite that long considering the 3870X2 is around 9.5" the voodoo5 6000 was probably to be 10.5" only :p
    Still a beast for the time though, with ridiculous heatsink for today's standards
  13. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    now that is a great pic. :thumb:
  14. TAG
    TAG New Member
    7 Aug 2002
    and here it is in it's backside support full length glory
    http://www.tweakpc.de/news/14076/ebay-3dfx-voodoo-5-6000-128mb-wird-versteigert/
    Looks like this particular one was auctioned last year. Best bid at the time the page was published was 1347€ :jawdrop:
    That's some nice collector's item :)
    Now with that support bracket that card may well have reached 11.5" which is the max length we've seen so far for a graphics card.
    It was referred to as a "full length" card, which I suppose is a standard coming from the server environment.
    Considering there is actually a standard for a card's maximum length, can we expect desktop oriented products to follow these server standards?
    I hope so since the mod I'm planning on my V2010 currently won't allow much more than 11.5" with the 14 hard drives in the front half of the case :dremel:
    These shots were described by ATI as those of an early engineering sample, but I doubt the design will change much (if at all) or to the point that they'll be able to fit 2x RV870 on a PCB the same size as a 5870 :(
  15. Trin
    Trin New Member
    8 Nov 2009
    This year is going to be interesting video card wise. I currently have a 3870x2, given to me by a friend, love this card. Would like to get a hold of one or two for crossfireX. Hope the 40nm process issues at TSMC get ironed out.
Tags: Add Tags
