News New Ethernet A/V standard aims to take down HDMI
Discussion in 'Article Discussion' started by CardJoe, 2 Jul 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. capnPedro
    11 Apr 2007
    Sounds good. As long as HD content doesn't sap bandwidth from the network. I wonder how it supports QoS?
    Who wants to bet that when it's released you'll need to buy a special proprietary router and a £50 RJ45 to HDMI/DVI/VGA/YPbPr converter box though?
  3. eldiablo
    eldiablo What's a Dremel?
    13 Jul 2005
    So will it be able to transmit its video over a home network? (supposedly gigabit) Or isnt it ethernet but it just uses UTP cables? If so, what will happen in you plug it into the home network.
    In either case sounds like a good idea, cheap to cover a large distance to a projector or something :)
  4. lacuna
    lacuna Minimodder
    9 Aug 2004
    You can spend as little or as much as you want on current AV cables and this will be no different. Unless there are some performance advantages over HDMI then its not particularly exciting. My NAS is already connected to my PS3/PC/AV amp by ethernet so its nothing new in that respect. Having the connector actually lock into the socket has its pros and cons of course
  5. yuusou
    yuusou Multimodder
    5 Nov 2006
    Reading the article, it seems like they'll just be using the UTP cables for A/V systems, and not other your LAN. Really, how would you do the routing? I think some people are being missing the point. It's like connecting your screen to your PC with an UTP cable instead of a VGA or DVI or HDMI.
  6. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    i have always like the convenience of ethernet cables specifically relating to the socket size and the clip mechanism iif this is able to replace agp / dvi i would be happy, if it were also to replace HDMI (i hate that they have no clips) i would be ecstatic
    also they are alot more flexible than most cable and would allow for far better cable management
  7. capnPedro
    11 Apr 2007
    Well that's confusing since Ethernet by definition is "a family of frame-based computer networking technologies for local area networks (LANs)." and they are named 10baseT/100baseT/1000baseT for consumer level standards.
    Using RJ45 jacks for data that isn't supposed to be plugged into a network would be ****ing stupid.
    Also, Valens Semiconductor's HDBaseT Receives HDCP Certification From Intel's DCP LLC. FFS.
  8. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    So you got a tv with ethernet and HDbaseT and you plugin you'r powered HDbaseT cable into your Ethernet port and in the process blow up your ethernet controller chip inside the tv. (since power over cable is one of the items of HDbaseT)
    I am also wondering what you pay for a 20meter Goldplated, triple twisted angel hair wired "Monster" cable. :p
  9. mrbens
    mrbens What's a Dremel?
    15 Aug 2009
    would the picture and sound quality be as good as an expensive HDMI cable tho?
  10. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    ever bought an ethernet cable from pc world, they aint cheap from there, cheaper to support your local indi pc store. or order online(delivery charges apply though)
  11. Bakes
    Bakes What's a Dremel?
    4 Jun 2010
    35ft cable inc. delivery for £2.99 on the Amazon Marketplace.
    If that's not a good deal I'm not sure what is!
  12. RichCreedy
    24 Apr 2009
    i image routing wouldnt be a problem, as they will make av routers/switches, then all those peeps with 19"racks can use the standard ethernet sockets they had installed all over their house, using the patch panels, simples.
    i think they may need to provide some sort of prorection though, to prevent damage caused by connecting to a standard ethernet port, POE etc
  13. RichCreedy
    24 Apr 2009
    @Bakes, free cable just paiying for delivery, lol, you cant beat that
  14. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    HDMI cables really aren't expensive if you don't purchase the silly priced ones from DGSi. My 360 is currently hooked up to my TV via a cable that cost me an eye-watering £1.50 from Amazon.
  15. LJF
    LJF Modded
    6 Jan 2010
    I bought 2x 1.2m hdmi cables (admittedly not 328ft!), delivered, from amazon for under £1.50... they do the job.
  16. RichCreedy
    24 Apr 2009
    i suggested to my sister that next time she wants to buy a hdmi cable to speak to me, as i didnt think the £70 3mtr cable she got from DSG was good value for money
  17. yakyb
    10 Oct 2006
    jesus did you make her take it back
  18. crazyceo
    crazyceo What's a Dremel?
    24 Apr 2009
    I picked up 300m of Cat6 cable on ebay for £35 and have at least 2 wired connections in every room, inc the bathroom! Picked up a Dell 42U server rack for £30 and a 24port Gigabit switch and patch panel for £29.
    Not got the gear to put into every room but the sockets are there and waiting for technology to catch up. My new TV has an Ethernet connection and links to YouTube via the internet connection and also uses my home server for images, music and video. however, some formats don't work so I need my mediacentre to do that part for me.
    So my main question Is it just a software issue for the TV?
  19. daletur328
    daletur328 What's a Dremel?
    5 Jan 2010
    The good thing about this solution is the fact that it may prevent signal drop that occurs on HDMI at lengths over 7-10m. I have about 15-20M, 30M with good routing, from my AV to other rooms and if it means that i can get HD 1080P pictures to my bedrooms TV without the need for either buying a new AV setup or SKY multiroom I will have saved a lot, and more importantly stay in bed longer.
  20. sandys
    sandys Multimodder
    26 Mar 2006
    You can buy this sort of stuff already, these guys are just standardizing it and integrating it into devices I guess, no good for your home network as your network is not going to be fast enough to send 1080p around the place.
    Requires Cat6/7 cable and hardware that can handle a few of gigabits
    an example.
    http://www.kenable.co.uk/product_info.php?products_id=1764
Tags: Add Tags
