New Forum Structure
Discussion in 'Article Discussion' started by Jamie, 29 Jun 2007.
  1. atanum141
    22 Jul 2004
    I think the casual forum members find it harder than the full-time members.
    Personally most of the threads i post in are well known.
    Might try the Greasemonkeh.
  2. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    Is this "greasemonkey script" open for all to use, if so where can one find it?
  3. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    A few thoughts, after having used the new layout for a while:
    1) I find myself browsing the photography forum a lot more - this is a good, if possibly expensive, thing (it inspired me to get a camera, and there's no way that it'll end there.)
    2) Not having a way to see what threads I've posted in is a bit annoying... If thread coloring could be opted to be new threads, threads I've posted in, or off, that would be handy.
    All in all, I like the switch - it's nice to be able to see all the forums on a single screenful.
  4. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    I assume from your second point that you want this because you don't like the new thread colouring and want to only see threads you've posted in and threads you haven't?
    *update*
    I've just added the option so you can disable colouring of new threads and/or the colouring of threads you have posted in. Enjoy!
  5. jezmck
    jezmck Minimodder
    25 Sep 2003
    glutton for punishment anyone?
  6. DougEdey
    5 Jul 2005
    It is open for all to use, you'll need to check with Ramble which ones he is using though. They only work on Opera and Firefox
  7. Tim S
    Tim S OG
    8 Nov 2001
    Doesn't the inbuilt forum search function work?
  8. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    nope,
    whatever the length of my search is
    i do appreciate the new, quieter icons on the threads, though. thanks for that.
  9. dacust
    dacust What's a Dremel?
    10 Mar 2007
    Signature size restriction - line counter anomamaly
    Looks like you are now enforcing the signature size restriction. I got no problem with that. But something is off in the way it counts lines. Does it maybe count the lines of text in the edit block? Even if I take all but 3 lines out it still says I have more than 5 lines. Because of the links in my sig, in the edit block it is several lines. Note: the sig below as I post is before editing as I have not saved any of my recent edit attempts.
    BTW: I wasn't sure about the new format until I used it a while. Now that I'm used to it I like it better than the old one. Easier to see where I've posted along with the new posts at one glance, among other things.
  10. RTT
    RTT #parp
    12 Mar 2001
    What keywords are you using - can you post an example please? :)
  11. Jamie
    12 Mar 2001
    Line breaks are lines too
  12. Delphium
    18 Mar 2007
    It does work to some extent, but guess im just a bit of a google whore, so its what I feel is easyer for me to use.
  13. Tim S
    Tim S OG
    8 Nov 2001
    Okay, fair point. If there are problems with it though, please do let us know so that we can diagnose those problems and fix them! :thumb:
  14. Nexxo
    23 Oct 2001
    I have had some problems with search when looking for 6-month old threads from before When It All Changed. Have they been included in the new forum?
  15. RTT
    RTT #parp
    12 Mar 2001
    What kind of problems Nexxo? :) The more detail the better.
  16. Guest-23315
    Guest-23315 Guest
    Its growing on me,but I stillthink we need some more forums.
  17. dacust
    10 Mar 2007
    Code:
    [NOPARSE]
    [SIZE=1][COLOR=Blue]My programs don't have bugs, they just develop random features.[/COLOR]
    [URL=http://forums.bit-tech.net/showthread.php?t=130744]WaterPlant worklog - in progress[/URL] - [URL=http://www.bit-tech.net/modding/2007/04/25/project_log_update_10/4.html]Bit-Tech article[/URL] - [URL=http://www.dacust.com/pcprojects]WaterPlant site[/URL] - [URL=http://www.dacust.com/index.html]Home Page[/URL] - [COLOR=DarkSlateBlue]PowerStation PC - Designing[/COLOR]
    [COLOR=Red]Don't worry about your english.  This is an international forum.  That's what makes it great.  If I don't understand, I'll ask.  Just MOD ON![/COLOR][/SIZE]
    [/NOPARSE]
    Code:
    This is only 3 lines (1 wraps on my screen, making it 4). If I try to add one more it says I have too many.
    And I realize line breaks would count. If I take my existing sig and remove the two line breaks, it still doesn't allow. I had the last /SIZE tag on a separate line, moved it up and still...
  18. Jamie
    12 Mar 2001
    That's a strange one, I have no idea how vb calculates the number of lines in that case.
  19. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    i get this problem too, i think that the problem is the length of the text (bb code included) reaching over the char limit, and it displaying the wrong error message.
  20. Jamie
    12 Mar 2001
    The char limit including BBCode is 1000, the char limit excluding BBCode is 500. Dacusts sig is within these limits.
Tags: Add Tags
