Windows New fps
Discussion in 'Gaming' started by Dayains, 28 Jun 2004.
  1. Dayains
    Dayains Notamodder
    18 Dec 2002
    tbh the only fps ive ever even been OK at is wolfenstein: Enemy Territory and im looking what game to go for next i bought hal life but key wont work with (i bought it new off play.com) and steam are taking the pisss with it.....ne ideas for a new fps....thanks :)
  2. acron^
    acron^ ePeen++;
    15 Oct 2001
    Wait for...
    Half-Life 2
    Doom 3
    Halo 2
  3. dom_
    dom_ --->
    4 Jan 2004
    farcry is cheap now, and worth every penny. if you have a hald decent graphics card you need this game. nothing out at the moment looks as good as farcry
  4. Nath
    Nath Your appeal has already been filed.
    28 Dec 2003
    I can second that. I'd say farcry is definately the best graphical experience out at the moment.
  5. Piratetaco
    Piratetaco is always right
    15 Apr 2004
    Ravenshield. if it don't kill you monitor(Like it almost did to mine) its great online.
  6. Nath
    28 Dec 2003
    Can I ask, how did it nearly kill your monitor modderman?
  7. Piratetaco
    15 Apr 2004
    right lets have a bit about games first. when you click on the exe for your choosen game the program starts up(the game)eg ut2k4.before i've even seen the Nvidia logo(or any logos,menus,intro's,etc) ,a map(containing no objects) has been started using the game's engine(in this game the unreal engine) this is at the res/detail levels you set the last time you played.this is so that the game only has to switch the monitor's res once,rather than between every level and menu. RS doesn't, it just sets you into the menu at 800 x 600. thus everytime you load a new level it has to switch from 800 by 600 to 1280 by 1024.this switch is indicated by a clicking noise coming from the monitor(only it seems on expensive monitors.yes mine did cost a lot).this would be ok if it was only 1 or 2 times a day but RS switches about 10 to 12 times during loading.
    links about the issue
    here
    another one
    here's the main one to read
    also ubi-soft aren't doing anything to fix this.
  8. Nath
    28 Dec 2003
    I didn't know about that....
    Glad that I do now though because I was thinking about buying raven shield for over the summer hols!
  9. Piratetaco
    15 Apr 2004
    its a good game if it works.but its not worth killing a monitor for.some unluck guy lost two $500 monitors playng RS,thats more than my entire PC!!
