Build Advice New gaming build, need a few pointers !
Discussion in 'Hardware' started by TheLink, 28 Apr 2012.
  1. TheLink
    TheLink New Member
    30 May 2010
    Hi guys,
    Will be building a new Ivy Bridge system shortly and would like some advice on a few components.
    Am based in New Zealand at the moment.
    Main uses of intended build: Gaming
    Monitor resolution: 1920*1200
    Will you be overclocking: yes, as achievable on air.
    Here are the compenents I have already ordered or owned from previous builds:
    Screen: Dell U2412M, 24", 1920*1200, IPS
    Graphic Card: Sapphire HD7950, Over Clock version, 3G GDDR5, PCI-E 3.0
    Case: Fractal Design Define R3 Black USB 3.0
    DVD drive: Asus DRW-24B3ST SATA Black 24x DVDRW Retail
    Storage: SSD Crucial 128GB M4 SSD
    Storage: HDD Samsung Spinpoint F3 1TB
    Sound Card: Asus Xonar DX
    OS: Microsoft Windows 7 Home Prem 64bit OEM
    Here is what I am decided on:
    CPU: i5-3570K
    Motherboard: Asus P8Z77-V LK
    And what I would like some recommendation with:
    Ram
    PSU
    CPU Cooler
    Keyboard
    Does this Motherboard fit well with this build ?
    Always had asus boards and never had problems.
    -What amount/brand/timings ram would you recommend ?
    -What power/brand PSU would you recommend ? Would like a modular PSU if not too much pricier.
    -Whith regards to CPU cooler would like something as silent as possible with some reasonable cooling to be able to do a reasonable overclock.
    -Keyboard: usecd to have a Sidewinder X4, might go with it again, any other recommendations for a keyboard with a few macro keys and backlighting with a nice feel ?
    Thanks !
  2. Bede
    Bede Well-Known Member
    30 Sep 2007
    Motherboard is fine (it's P8Z77-V rather than -U I think).
    Corsair Vengeance @1600mhz would be fine, IB is the same as SB in that it doesn't make much difference what RAM you use.
    Gelid Tranquillo is a good and cheap CPU cooler, BeQuiet! Dark Rock ones are better and more expensive.
    PSU - anything branded above 500W would be fine. Get one with an 80PLUS gold/silver rating.
    Other than that, just look back through bit-tech's reviews.
    TheLink likes this.
  3. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
    TheLink likes this.
  4. TheLink
    TheLink New Member
    30 May 2010
    Thanks for the replies.
    It is indeed Asus P8Z77-V LK.
    Had a look at PSUs and probably going to get Corsair HX-850 850W would give me headroom for further expansion, is modular, is of great quality ad has a 7 year warranty !
    Had a Gelid Tranquillo on my previous build which was great but cannot find it here in NZ ! Same for BeQuiet! Dark Rock and Arctic i30.
    Considering Noctua NH-D14, but it is £100 equivalent.
    What about Corsair Hydro Series™ H70 ? It is £70 equivalent over here.
    Any other suggestions otherwise ?
    With regards to ram, is it worth going for 1600Mhz ram ? And shoud I go for 4, 8 or 16GB ?
    Edit: Ram wise looking at this:
    Corsair Vengeance Low Profile DDR3 PC12800/1600MHz CL9 2x4GB 1.5V (CML8GX3M2A1600C9)
    http://pricespy.co.nz/product.php?p=916997
  5. TheLink
    TheLink New Member
    30 May 2010
    Looking at COOLER MASTER HYPER 212 EVO COOLER for £28 equivalent with thermal paste.
    Got some good reviews.
    Any thoughts ?
  6. mikeyman198
    12 May 2011
    That RAM is perfect, and the 212 Evo is pretty good :)
  7. TheLink
    TheLink New Member
    30 May 2010
    Order placed, thanks for the input guys :)
  8. heir flick
    heir flick Active Member
    2 Feb 2007
    The corsair psu is a good choice, i dont think you can go far wrong with them
  9. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    i'd go with 8 gig of 1600 RAM and an Antec Kuhler H2O 620.
