Build Advice New Gaming PC
Discussion in 'Hardware' started by twun, 23 Nov 2014.
  1. twun
    twun What's a Dremel?
    13 Nov 2014
    Hi folks,
    My 6 year old pc is in need of a refresh, the original was built from recommendations from this forum and has performed admirably for all that time. As always I'm looking for the best bang per buck.
    Budget:
    600-800
    Main uses of intended build:
    Gaming (CSGO), programming, Web browsing
    Parts required:
    CPU Motherboard Ram GFX SSD
    Previous build information (list details of parts):
    CPU: I have a Q6600 over clocked to 3.4ghz
    MB: Asus p5e x38
    RAM: Corsair cx750
    Hdd: 36 Gb Raptor + 2 x Samsung 75gb in raid 0
    Sound: Xonar Dsg
    Monitor: Samsung 226bw
    Gfx: 650ti
    Monitor resolution:
    1900x1200
    Storage requirements:
    Will keep Samsung hdds
    will you be overclocking: yes
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): not really nothing out of the ordinary.
    Extra information about desired system: I am looking at getting the iiyama 2248 to replace my monitor which I have taken out of my budget already. So leaves 600-800 for all the other bits.
    Thanks for any input :D
  2. twun
    13 Nov 2014
    Ok so i started to spent sometime researching and came up with this
    http://uk.pcpartpicker.com/user/twun/saved/XYbV3C
    I have a coolermaster stacker 830 case, which is a good air cooler to go for that will fit I want to do some mild overclocking?
    are there any parts you would change?
    thanks again
  3. Anfield
    Anfield Multimodder
    15 Jan 2010
    Looks all good.
  4. Blogins
    Blogins Panda have Guns
    3 Aug 2010
  5. twun
    13 Nov 2014
    Gosh two hours late and it's ended that was quick!
  6. twun
    13 Nov 2014
    well i finally bought all my parts, with the black friday + cyber weekend i managed to get this build for £700, saving of just over £100.
    cant wait to put it together :D
  7. Mumbie
    Mumbie What's a Dremel?
    18 Nov 2014
    Nice, very expensive but nice build. i think i7 is overkill for gaming and for single gpu you won't need oc and evga was a bad choice, the cooler on the 900 series evga cards are misplaced ( they re-used them from other vgas). As far as i know the only good 900 vgas are from Gigabyte (the G1 gaming) and Asus. (evga crap cooler, msi cheap stuffs and loud coil whine)
  8. twun
    13 Nov 2014
    yeah i know the i7 is overkill, but i didnt find any deals on i5s and for the same price as i got i54690k + msi mb i could get the i74790k and the Asus MAXIMUS VII RANGER, so to me there is no loss.
    ok thanks about the evga cards, this is the first i have heard of that problem, i will look more into it.
  9. twun
    13 Nov 2014
  10. Mumbie
    18 Nov 2014
    The problem is this. Firmware updatre won't solve it.
  11. twun
    13 Nov 2014
    Ok can you post a source so I can read up?
