new gigabyte ga-7vt600-L problems
Discussion in 'Hardware' started by dreamreality, 16 Apr 2004.
  1. dreamreality
    dreamreality What's a Dremel?
    4 Mar 2003
    i just intalled this board for my dad with his 1700+ and now it wont read the chip at the proper speeds. i updated the bios to the latest version it still wont read it at its rated speed. it only shows 1100mhz right now when it should be at around 1400mhz. any1 kno how i can fix this? thanks
  2. kenshin
    kenshin Banned
    22 Feb 2004
    check the motherboard manual for jumper settings to set the multiplier. The mutliplier selector might also be a block of dip switches (normally bright blue).
  3. dreamreality
    4 Mar 2003
    ahh yes thanks for the tip i just saw the jumper. it worked thanks!
