Build Advice New graphics card and HDD
Discussion in 'Hardware' started by hardtailstar, 27 Jan 2011.
  1. hardtailstar
    hardtailstar "insert title here"
    1 Jun 2009
    Hello All,
    im after a new graphics card and Hard drive.
    i currently have an old graphics card and hard drive which i dont know what they are as they are about 5 years old.
    the motherboard i have is an Asus p5k64 ws
    any help would be great or any questions just ask.
    Thanks
  2. murraynt
    murraynt Modder
    6 Jun 2009
    Do you have a budget? Other wise it's pointless as the best would be a 580GTX.
  3. Uxon
    Uxon Minimodder
    14 Dec 2010
    Which CPU do you have and which resolution are you playing at?
    Also what's your budget for the upgrade? You could either get a standard HD like the Samsung F3 or an SSD like the Vertex 2E (scroll down to the OCZ section of the Today Only deals.)
    edit: Also if you only have 2GB of RAM then a memory upgrade could also be a cheap and effective upgrade.
  4. hardtailstar
    1 Jun 2009
    haha sorry my budget is about £200 for both
    i dont play games but usually its whatever i find best for me and the monitor.
  5. Cookeh
    Cookeh What's a Dremel?
    4 Jun 2010
    What's the resolution of your monitor?
    For £200, I would be looking at a Radeon HD5850 and a Seagate Barracuda 1TB HDD (the Barra is the fastest HDD out there atm! :eeek:
    All underlined things are clickable :p
  6. Deders
    Deders Modder
    14 Nov 2010
    or a GTX460
  7. murraynt
    murraynt Modder
    6 Jun 2009
    What's your current GFX not doing ATM? If you need a new one for occasional gameplay a 786mb 460GTX will be loads. But more importantly you can get a 64GB SSD and keep your existing HDD for storage.
  8. Cookeh
    4 Jun 2010
    True, but out-performed by a HD5850 :p
  9. hardtailstar
    1 Jun 2009
    right you should probably know more about my comp......
    motherboard: Asus p5k64 ws
    graphics card (found box): NVIDIA GeForce 8500 GT @ 1680 x 1050
    ram: 4GB
    CPU: intel core 2 duo e6750 @2.66 ghz
    HDD 160GB (on its last legs)
    OS: windows 7
    what i want to do.....
    to be able to watch videos and dvds.
    the only game i have for my pc is FM 2011 and i use an Xbox for the rest.
  10. hardtailstar
    1 Jun 2009
    was looking at SSD and keeping mine for storage but as it could be on its way out atm i dont really want to chance keeping as storage internally.... i do have an external HDD i use for storage/backup atm.
  11. murraynt
    murraynt Modder
    6 Jun 2009
    The above rig should be fine for watching videos. Storage wise it would probably be the Samsung F3 1tb. If you want more GFX power a 786 460GTX will fit the bill perfectally at around 110 pounds from scan.co.uk
  12. hardtailstar
    1 Jun 2009
    yeah it is but both the graphics and HDD are starting to go.... i forgot to put that in my OP.
    thanks for the help will look into them.
  13. mucgoo
    mucgoo Minimodder
    9 Dec 2010
  14. Uxon
    Uxon Minimodder
    14 Dec 2010
    You probably want to be careful with your choice of graphics card, although you don't need a particularly high spec card for watching videos, you will want one with a 6 pin PCIE connection (or an older card) as the more modern cards which just take power from the motherboard are designed for PCIE 2.0 motherboards (which provide more power to the PCIE slot.)
    Something like this would probably be okay:
    http://www.ksn-online.co.uk/components-video-cards-peak-512mb-radeon-4850-pci-hdmi-p-8122.html
  15. Deders
    Deders Modder
    14 Nov 2010
    True, except when tesselation comes into play :p
  16. murraynt
    murraynt Modder
    6 Jun 2009
    :duh: I read the post above as Formula one 2011.
    Check (Wait for it) There are some cracking deals on 8800Gt's. There are going for around sub 40 pounds. Pair that along with a F3 1tb and maybe an SSD and you are sorted.
    Also look at something like a 5670.
  17. Uxon
    Uxon Minimodder
    14 Dec 2010
    Link? Just had a quick look and I can't seem to see anywhere stocking them that cheaply.
  18. murraynt
    murraynt Modder
    6 Jun 2009
  19. Cookeh
    4 Jun 2010
    Not so sure about that, any benchies to prove that?
    Anandtech shows clear wins for the 5850 :p
  20. Uxon
    Uxon Minimodder
    14 Dec 2010
