New Graphics Card for DELL 6400 Lappy?
Discussion in 'Hardware' started by keef247, 7 Apr 2008.
  1. keef247
    keef247 Minimodder
    11 Aug 2006
    inspiron 6400...
    i think the x1300 ati card is pci-e... so it can be replaced right?
    its a 1.6 core duo (not c2d) 1gb ram...
    i was thinking something like a 8500/600 card...
    if so i can just unplug the other and connect the new one right?
    any ideas?
    cheers
  2. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    You'd probably find the most information by looking at Dell's support pages, but don't get your hopes up. The card uses the PCI-e interface, but that just means the logic controlling it is based on PCI-e. The physical connector and layout is very likely proprietary. It's the same situation we had a few years ago when many onboard video chipsets were advertised as "AGP Graphics." Technically, they were, but for any purposes that mattered they were just onboard video.
  3. keef247
    keef247 Minimodder
    11 Aug 2006
    is there any way i can tell if i open it up.it hasn't got warranty anymore...
  4. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    X1300? unfortuantely i believe that is an IGP card that you cannot remove, im not 100% sure on that so do no quote me. If that is the case though then you cannot upgrade/remove it.
  5. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    X1300 is dedicated, X1100/1150 are the integrated ones, but the GPU might still not be removable for other reasons, like being soldered on the mobo or something.
  6. keef247
    keef247 Minimodder
    11 Aug 2006
    gravemind did you mean isnt dedicated?
  7. keef247
    keef247 Minimodder
    11 Aug 2006
  8. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
  9. Gravemind123
    26 Aug 2006
    I meant dedicated in the fact that it is not built into the chipset or anything, there was never an integrated graphics core called X1300, that was a dedicated core, however, it could be that they form factor of it is a ball-grid array or something else that would make it nearly impossible to remove.
  10. mctigger
    mctigger What's a Dremel?
    11 Feb 2007
    i have the same lappy, unfortunately im 99.9% sure it can not be removed as it is solder to the mobo!!
  11. markjw
    markjw What's a Dremel?
    4 Aug 2007
  12. genesisofthesith
    genesisofthesith complete spanner
    4 Dec 2004
    With my fujitsu siemens Amilo Pi1536 the x1400 can be replaced with a few mxm modules as its a standard mxm class 2 slot, but dell have used proprietary connectors in the past, so even if its a removable pci-e card it may not follow mxm standards.
    http://www.mxm-upgrade.com/Notinthelist.html
  13. keef247
    keef247 Minimodder
    11 Aug 2006
    how much better is a x1400 over a 1300?i know the 7300 is overpriced and underpreformed compared to the 1400 but I'm unsure how much better a 1400 is over a 1300
  14. Gravemind123
    26 Aug 2006
    The X1400 form what I can tell is an X1300 core with slightly higher clocks and more v-ram. In all honesty, you probably could just overclock the X1300 a bit(assuming mobile cards are supported in ATI Tool or something, of that I have no idea) and get similar performance to an X1400. The first real step-up is an X1600 on ATI or GeForce GO 7400(maybe not even that big of a step there) or 7600.
  15. skybarge
    skybarge just chilling at work
    29 Feb 2008
    Yeah I'm pretty sure you can run Rivatuna on it, i've got a work Dell D620 here and I've got the 7300 which I've got beta drivers overclocked for, not that it makes too much difference, what are you trying to run?
    the 8500/8600 are alright for most games, but won't fit in the slot where your X1300 went, they are a larger size and have a bigger heatsink on them
    I'd go for a 7600GT if Dell still have any lying round, they probably don't :(
  16. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    You can bolt in a 7900GS, I think, but the problem is you'll have to modify the existing cooling to accept the core, and then hope that it can adequately cool it. The 7900 is for the 9400 / 1700 units. I have the same lappy as you, and i've searched this avenue before...
  17. Splynncryth
    31 Dec 2002
    From messing with some Dell laptops, I think they have been using the ATI AXIOM interface, it certainly looks like the physical interface. If that's the case, there are a lot of potential cards, but it would take some serious hacking to make them work physically. With the cost of the cards, and the potential for disaster, it does not seem to be worth it.
  18. fantastic dan
    fantastic dan Minimodder
    26 Jan 2004
    The x1400 will fit that laptop. I don't think any others will.
    Dell don't use either the Axiom or the MXM modules. It's a proprietry Dell design, so you won't be able to swap it for a model from a different company.
    The problem is that some of the machines are interchangable without the card being offered. The 9400 would take a 7950gtx but you couldn't buy one because you have to flash the bios but I don't think the 6400 has the same internal design as any other dell laptop.
