New Gskill
Discussion in 'Tech Support' started by WarningFromSpace, 4 Jun 2006.
  1. WarningFromSpace
    WarningFromSpace What's a Dremel?
    1 Apr 2006
    Alright, so its been a while since ive had any real problems with my computer so im a bit rusty. The story goes like this, I purchased some Gskill extreme pc4000 2gb set. I install it and run it at the 250 stock. Everything seems fine, cpuz and everest see it and display the right timings and speeds. So I decide to play some UT04 and a few minutes into my game i hear the audio jitter then loop as the game freezes. I manually restart my system and set it back to 200 and CSS is fine. What do you guys think i should do? More voltage or loosen timming? Im not sure...
    http://www.newegg.com/Product/Product.asp?Item=N82E16820231021
    ^link to ram
    MSI MSI K8N Neo4
    AMD 64 3200+ venice
    WD 80gig
    Evga 6800GS
    Sound Blaster Audigy 2
  2. hitman012
    hitman012 Minimodder
    6 May 2005
    What timings and voltages were you using?
  3. WarningFromSpace
    1 Apr 2006
    2.6 and 3-4-4-8 when it was set at 250, now same timings and voltage but 200
  4. WarningFromSpace
    1 Apr 2006
    Got it working :D It did not like me manually setting the timmings. I set it on auto and the timmings it found were correct. Then I slowley worked my way up to 250 and its happy now. Also working my way from 3htt to 4 after i set the fsb helped. w00t w00t 2 gigs
  5. WarningFromSpace
    1 Apr 2006
    OK finaly solution, it turns out the socket for the ram was not secure. I went in after more troubles occured and the ram was like a loose tooth from 3rd grade! Now after moving the stick mem test goes for hours and I can own mah clan in CSS all night long. :D
  6. Krikkit
    21 Jan 2003
    Whoah, that's dangerous. Lucky you didn't lose some RAM there matey.
  7. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Thats damned lucky. I've had the smell of fried/smoking ram through that.
    My own lazy fault though.
  8. WarningFromSpace
    1 Apr 2006
    yeah I got lucky :) Too bad its still acting up, its lasting longer in css now :rolleyes: Any ideas guys?
  9. WarningFromSpace
    1 Apr 2006
    Ok so pictures will help.
    Bumped up the voltage from 1.4 to 1.425 10x multi 4xhtt and 250fsb. This im not sure will help because I was doing 2.5 with dividers on 1.4
    This look right?
    Should be 3-4-4-8, but ive read others that say cpuz shows it like this too
    Now for the complex timings and what-not
  10. Firehed
    15 Feb 2004
    I've got the same stuff as you, though mine's only running at 240 or something (could well be that the ram was at fault, I was happy enough with 2.4ish ghz). You said you're at 2.6v, correct? Try upping it to 2.7v and see what happens. According to Newegg, it's rated 2.6v-2.8v. Some boards will over or undervolt a bit, so I'd check that out.
    Run memtest86 too, it's possibly not your memory at fault.
    Also, one word: "edit"
  11. WarningFromSpace
    1 Apr 2006
    Alright Just got back from CSS and everything seems in order. I think the extra vcore helped.
    Firehead, the reviews ive seen have the ram going up to 275 on 2.6 they said more voltage does not help it any. I have memtest pro and im about to get that running. When it was working smooth before I had it going for about 5 hours. And wth is an edit? That like german or something? :confused:
  12. Firehed
    15 Feb 2004
    well, that would explain it anyways...
    edit meaning that button next to quote, rather than triple-posting.
  13. WarningFromSpace
    1 Apr 2006
    I know where the edit is :p
    If it bothers you from now on when I come close to double or triple posting ill think what would Firehead do?
    And the ram went memtesting while i slept so 4 hours roughly. Im planning on pushing it further now, since other have gotten 275 :D
