ok im looking for a new heat sink for a socket T/LGA775 pent4 3.06GHZ ok what i want to know is: what is best internall/materal that it can be made out of what ones have the best themal resitance and possibly where can i pick 1 up
a XP-120 would be the best, its made with a coper core and the rest is aluminum. i think for that socket you need a adapter. the best fan is the last one on the page. good luck finding one in the US the best materals are in best to worst order dimond silver copper gold aluminum wood
Holy crap! 59dba! I think, if i put all my computers next to each other in one place, they would not total 59dba! Do they come with a pair of ear plugs?
if by "best fan" he means highest airflow then its not far wrong, but i got one of those fans for comedy value and trust me its bloody hilarious, think hoover+hairdrier+lawnmower and its almost there. imo the best 120mm fan papst, enough airflow and quiet as can be wont go far wrong with panaflo or silenx as well (even if the specs of silenx fans look absolutely amazing, they have their own "special" way of rating them and in real life theyre not far different to good papst and panaflo fans)
The pick up http://heatsinkfactory.com/cgi-bin/HFAstore.pl?user_action=detail&catalogno=CF-034 from the same store - a much better quality model.
dude im not looking for 120mm fans!!!!!!!!!!1 come on ppl!!!!!!!!!!!!!!!!1 lga775/socket T heatsink!!!!!!!!!!!!!!!!!!!!!!!!!!1 please help me
Id buy a new keyboard if i were you - that "1" key looks a tad sticky. No the thermalright doesnt look like it supports LGA sockets, infact hardly anything does atm A lot of LGA boards have caps real close to the heatsink area so anything out of spec is more than likely gonna have problems. If you can get a retail intel heatsink they are very good! although do take your fingers off cause the fan is unguarded.
i have a intel heatsink and i get like 160 when i play halo i need a new heatsink or some kind way to fix this and why dont they make LGA775 heatsinks?? is it beacuse the slot it newer?
