Other New home cabling
Discussion in 'General' started by Awoken, 25 Jul 2017.
  1. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    We're putting in an offer on a new place and I want to get cables run out of sight from the office, on one side of the house to a couple of other rooms. We're replacing the carpets downstairs with laminate and I need the cables to run from the utility room to the kitchen, the office and into the lounge on the other side of the house (we run plex throughout the house. I might even run one to the upstairs hallway just in case our Asus A68U wifi doesn't reach - its a bigger house than we're currently in).
    As a student I just ran cable along skirting boards and used a little white trunking to cover it up but now that we're getting our own place (finally moving out of rental accommodation) I want to get it tucked away and with proper faceplates rather than loose RJ45s.
    What's the best way to run cable in a relatively new build and where do I start my search if I want to get someone to do it for me (including making right afterwards)?
    Is Cat 6 worth it when most TVs/set top boxes are 10/100?
  2. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    CAT6 shielded is worth it if you ever plan to use HDMI over CAT as you'll only only get full quality over longer distances with shielded.
    You might be best to pay a sparky to poke the wires through the walls because it'll be a load of effort otherwise to make it neat.
    If you keep your cables to the outside walls you might be able to weave them through the dots and dabs plus the ceilings downstairs are largely hollow with a reasonable gap you should be able to run through. For upstairs you can poke cables down from the loft too.
  3. yuusou
    yuusou Multimodder
    5 Nov 2006
    Go all out, go CAT 6A blinded and reinforced (plastic bit in the middle). Its your house, I doubt you plan on leaving any time soon, make your house future proof.
  4. Gareth Halfacree
    4 Dec 2007
    If you're paying someone else to do it, CAT6A; if you're doing it yourself, CAT5e 'cos CAT6A is an absolute bugger to work with.
    Also, bear in mind the installation rules for CAT6 and above: they require surprisingly wide bend radii, which every amateur installer always gets wrong and makes the entire installation sub-CAT6 (meaning you might as well have saved time and effort and bought CAT5e in the first place.)
  5. Awoken
    3 Mar 2004
    Thanks for the advice. Does anyone know a good cable thrower near Rugeley, West Midlands?
  6. Kronos
    Kronos Multimodder
    6 Nov 2009
    Running cables under floorboards is a pretty simple task even adding sockets to walls is not difficult if you are a reasonable DIY'er though getting one upstairs will be more problematic.
  7. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    If you're running everything fresh, RUN FLEXIBLE CONDUIT. That way you can pull whatever cable you need yourself, and replace it when necessary. Pull Cat5E for basic drops, Cat6A if you want to run HDbase-T extensions, pull fiber if needed, etc. Conduit + a pull cord (pull a new cord through with the cable whenever you run a cable) and you never need to worry about chiselling out the walls when you need an extra drop.
    silk186 likes this.
  8. Zoon
    12 Mar 2001
    Modern builds are concrete screed in ground floor and flame/rot retardant-treated MDF boards on first floor.
  9. Awoken
    3 Mar 2004
    Sadly I am not an experienced DIYer (computers, networking, mobile phone repair, rockets, high altitude balloons and custom electronics are no problem - I dont have the first clue about plasterboard, house layout, etc) and due to limited time I really need someone who knows what they are doing. Any help (even search terms) would be greatly appreciated.
  10. Kronos
    Kronos Multimodder
    6 Nov 2009
    Fair enough, I am fortunate to stay in an older property (1925) so wooden floorboards are reasonably easily uplifted. I suspect the age of your house will determine how the job will be done.
    Try Googling Home Network Cat5/Cat6 cable installers and adding your area.
  11. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Any recommendations for cable to run from my house to my "summerhouse"? Currently using home plugs over the power wires.
  12. edzieba
    14 Jan 2009
    - Armoured outdoor-install Ethernet (up to 100m). Easy, 'cheap' (get the proper cable designed for buried installs, by the time you've mucked about weatherproofing indoor-use cable you'd have spent the same amount anyway), plugs right into existing infrastructure like any other cable.
    - Outdoor fibre run + media converters at each end. No issues with interference or grounding, fibre itself costs around the same as buried armoured ethernet, but the media converters are an added cost. Can allow for massive ranges if needed, and can in the future expand to much greater bandwidth by swapping the media converters. Get a pre-terminated run or find someone with the equipment to terminate fibre properly: proper termination determines the quality of your link.
    - Wireless point-to-point link. Line-of-sight only, but no wires to run and can achieve a very clean install for rather long distances (up to many hundreds of metres, potentially multiple kilometres). Can be relatively cheap (e.g. a pair of Ubiquiti LiteBeam units can be had for ~£150 for a half-gigabit link).
    silk186 likes this.
  13. Sp!
    Sp! Minimodder
    6 Dec 2002
    I use external grade CAT5 from cpc for my garden office (about 35m run of which about 20m is outside) I've run normal internal grade out to the shed (cheap stuff from screwfix) and that's been in for years without any problem.
    Armoured is overkill unless your going to bury it, all of mine is just tucked at the back of flower beds and I know it's there so won't be putting a spade through it any time soon.
  14. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Depending on your resources to pay for this you may wish to consider installing low voltage conduit. Then you can install ethernet, video, audio, etc. Plus one can then add, upgrade and or replace the cables as required. Down side is it does require ripping open your walls to install. I'd go with 1" to conduit then you'll have enough room to pull cables with manufactured connectors.
    Despite what other have recommenced I would caution the use of shielded cables as improper grounding of the shields can create current loops and generate its own issues. To use shielded cables properly you'll need equipment with RJ-45 jacks that are designed to engage the shield. The last I had heard only some enterprise and industrial grade switches are equipped with jacks for shielded cables. In short you'd be wasting your money on a product that potential could give you a lower performance.
    Similarly I'd consider installing an underground conduit between buildings. You'll need to look into local building/electrical code as to the design but it will allow you to install a much cheaper cable and provide flexibly for future. For your application I'd consider a larger conduit 2" maybe even a 3".
  15. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    A friend of mine ran ethernet to his garage workshop (for 3D printer & laset cutter) inside a garden hose clipped to the fence along its length. Way cheaper than conduit.
  16. MadGinga
    MadGinga oooh whats this do?
    19 Mar 2009
    clever.
  17. silk186
    silk186 Derp
    1 Dec 2014
    This is what I was going to recommend. It isn't as big of an issue in North America due to crawl spaces but i still ran a conduit from my receiver to the TV as standards change every couple of years.
