Modding New Ideas for security??
Discussion in 'Modding' started by funkymunky, 8 May 2003.
  1. funkymunky
    funkymunky Guest
    yeah i thought about doing that, but as i said before, my little brother is a sneaky one!
    He could just remove the hard disk, but if i had something like a smart card, it wouldnt even boot so he couldnt do it through dos!
    And a smart card would be a good idea, becuase i could use security screws to stop entry to the casing :nono: "thats bad!"
  2. Dad
    Dad You talkin to me?
    15 Apr 2003
    Those are nice, but the problem still remains that they would be defeated easy if you have access to the computer itself. If the computer is in a locked cabinet or is secure, bio-secutiry will work fantastic.
  3. linear
    linear Minimodder
    5 Oct 2001
  4. funkymunky
    funkymunky Guest
    yeah your right, that would work fantastic if nobody would get access to the main unit, i dont think i have enough room in my room to fit a bigger cabnet (custom made desk!)
  5. ajack
    ajack rox
    17 Apr 2003
    lol what is on your computer that your brother would go to so much trouble to see?! Removing the hdd seems a bit extreme. Cant you just puit your files that you dont want him to see on a usb pen drive and password it?
  6. funkymunky
    funkymunky Guest
    its not just my brother, my parents run a Bed and Breakfast so we have some weird people come into our house all the time, and because alot of the time the house is unsupervised then people may use the computers......
    I figured that a usb pen could be taken and then they could use a password cracker or sumthing of that type to decode the password.....
    A smart card would be brillant, because the computer will be bolted to the desk, and then the desk and the computer would have to be removed, and they would be hard pushed to get that down the stairs of my room :D :D :D
  7. funkymunky
    funkymunky Guest
    lol, i have one more question, and i promise that this isnt a trick or that im taking the micky, but is the card waterproof???
    it must only be a network of connections to enable the device to complete the circuit i would assume??
  8. Dad
    15 Apr 2003
    Hey Linear... That software fanbus thing... Where is that!? It's not on the cd I got!
  9. craigey1
    craigey1 Minimodder
    13 Jan 2003
    Umm, am I being stupid in suggesting using a BIOS password on Boot. Just make sure that you have a strong password (ie upper & lowercase characters & numbers, even use special characters).
    You could also password protect windows using a strong password, then if the BIOS is reset, they'll have to work out the password to get in to windows. Obviously this works much better if using either NT / 2k / XP.
  10. Dad
    15 Apr 2003
    All you need to do to crack that is to open the computer and reset the cmos. Easy. Again, if you have access to the computer itself, it's very easy to crack or bypass any security - well, that I know of that is...
  11. funkymunky
    funkymunky Guest
    To put this simply, my brothers a computer boffin, and i am not :D
    he could easily just kill the bios, some how i dont know, but i belive it can be done through windows....... and then he would use Msdos to get any information he needed and then upload it to his computer or something......
    But if my brother can do this then whats to stop other lodgers or people using my computer, i really like the smart card idea, because theres no way past it, u flash the bios, and nothing.......
    But i have 1 thing to ask....
    when its taken out during windows.......... does the system still stay the same as before, or does it change and goto bios etc........
    that would be such a cool idea to use the smart card idea, i cant believe i didnt think of it before, i even asked another computer boffin, who thought of everything apart from that :D :D :D
  12. pheonix
    pheonix Toot Toot!
    14 Mar 2001
    How devious is your brother exactly?? I mean he'd format your PC to get at it? :eeek:
    Fingerprint scanner for windows login, password the bios (tell it to only boot the HDD and nothing else), then lock the side panel with a padlock?
    Not entirely sure what else you could feasibly do!?
    EDIT: OK Smart cards a good idea :D
  13. Dad
    15 Apr 2003
    I'm not sure you fully understand this. Is you enable the SCR, you won't bea able to do anything without the card. The computer won't even get to the bios post. It wil be like you installed it without memory. Nothing will happen at all. As Linear said, you lose the card, you toss the motherboard and buy a new one so there is an inherant danger in doing this.
    Not 100% sure on that as I don't use the card myself. The capability is there, but I never used it as my office is pretty secure in and of itself. Someone gets in here, I've got more to worry about than them getting stuff off my hard drive! ;) However, I *believe* that the computer won't even function without the card.
  14. funkymunky
    funkymunky Guest
    right so the unit could just blank out :lol: i like the idea!!
    my brother is extreamly devious to say the least, but its not really my brother im that worried about its people i dont know coming into our house....
    I know i sound stupid when i say i want soo much security but its something ive been meaning to do in our house
  15. pritsey
    pritsey Minimodder
    26 Nov 2002
    How about going lo-tech.....lock your room!!!!
  16. funkymunky
    funkymunky Guest
    lol, that would be a good idea, but the way my room is made is, that my room is made up on the loft, nice loft conversion so theres no way i could lock the room!
  17. Dad
    15 Apr 2003
    It'll either do that, do nothing or the computer will turn off hard. Not sure which...
  18. funkymunky
    funkymunky Guest
    Ill try and find out, surely someone must have a smart card unit
    :thumb: Thanks you guys you've been extreamly helpful!!!!!!
  19. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    a big stick :D
    if your brother (or anyone else for that matter:p) goes near it beat them with it, they'll soon learn :clap:
    hook up a webcam as a security camera too, then you'll know who did it and can beat them with impunity :lol:
  20. funkymunky
    funkymunky Guest
    :thumb: wicked!!!!!!!!
    Ill do that!!!!!, seems the ultimate security device!!!!! :D :D
