News New Innovatek Water-Cooling Eqipment at Virtual-Hideout
Discussion in 'Article Discussion' started by GreatOldOne, 29 Jun 2003.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    Virtual-Hideout has a review on some new WC gear from Innovatek - There's a new Water-Block, Pump, Tank-O-Matic Plug-on and an Inline Temp. Probe:
    "Installing all the equipment was literally a 20 minute process from start to finish. After draining the existing water-cooling system, I disconnected the tube from the pump and waterblock. Mounting the waterblock was as easy as mounting a heatsink. I applied thermal compund on the CPU, placed the waterblock on, then clipped the mounting hardware on to the socket and tightened it down. I cut the intake tube in half and installed the inline temp. probe, then connected the tube to the waterblock. With the waterblock connected, I next connected the GPU waterblock outlet to the reservoir's intake, and connected the pump's outlet to the radiators intake. Everything was connected, but then I decided to hook in the old Tank-O-Matic simply because it was still mounted to the back of the case."
    Full review here
  2. [twig]clown
    [twig]clown What's a Dremel?
    1 Jan 2003
    Me thinks he may have his CPU and Case temps mixed up on MBM5.....
    -cLoWn
Tags: Add Tags
